Big shot help
Old Oct 25, 2008 | 11:03 PM
ChevPower's Avatar
Default Big shot help
Ok i'm looking for some big shot help or opinions.
My setup is a progressive direct port jetted with boxed 40 jets with a stand alone with 116 octane, the motor is on 93 octane.
I have been running a direct port for years and have always had to spread my jets to get my AFR up. example my 300 shot i ran 32f and 36n and 6psi on the standalone when my motor tune was good.
Right now i have it boxed at 40 and am down to 4.5 psi on the fuel and even takin fuel from my motor tune and i just cant get the AFR to move off of 10.1.
I was thinking i would keep pulling fuel from my motor tune (injectors) untill i have my desired AFR, My thoughts on this is i would end up with more 116 octane than 93 witch should be a good thing. or should i just spread the jets? If I was to spread the jets i was thinking 40f 42n.
If anyone here has ran a direct port jetted at 400+ i would love to here about it.
Old Oct 25, 2008 | 11:53 PM
next's Avatar
Why are you running 93? I personally would have it 116 in both tanks.
I liked running my squared (40/40) and pulling from the low pressure side like you are doing. Have you been checking your plugs to make sure it matches what your w/b says?
If that's a match, then I would go a 42 jet, up the low psi and start working back down again. Of course, I'd only start leaning it out with good fuel in the tank. I would leave the motor tune alone if it's dead on.
Old Oct 26, 2008 | 07:49 AM
ChevPower's Avatar
Yes the plugs are reading very fat. I think i will just try a 42n jet because if I lower the fuel pressure anymore I'm afraid the lean spike my scare me lol.
I will add 116 in the main tank as well to help keep it on the safe side if there is such a thing lol
Old Oct 26, 2008 | 08:06 AM
smokeum99ta's Avatar
He had some similar issues with my car. Come to find out the nitrous silinoid wasn't working correctly. The noid was getting stuck shut after the initail hit. Thank god it was stuck closed not open. What kind of noid are you using?
Old Oct 26, 2008 | 08:53 PM
ChevPower's Avatar
The big NOS 4 noid setup I am sure the noids are working 100%
Old Oct 26, 2008 | 09:03 PM
next's Avatar
I think the 2 jet spread and 116 will be a good start. I'd up the pressure to around 6 - 6.5 after the jet change.
You will only need to make a 330' hit and the kill the motor and coast out the back to get a read on what the tune is doing. After you get it dialed there then you can make some full passes and recheck.
One of my favorite passes was on a test hit with a 38 jet. Shut it down at the 1/8th and still ran a 10 second 1/4 mile.
Old Oct 27, 2008 | 09:06 AM
ShiznityZ28's Avatar
2-4 spread is almost alweays needed. squared 40's are on the edge of to rich enough to melt ringlands.
Old Oct 27, 2008 | 09:07 AM
ATVracr's Avatar
I think you'll need closer to a 4 jet spread to get it perfect.
But I'd rather run a little leaner than most like these days.
when you get in the 40's thats alot of N20...
Old Oct 27, 2008 | 10:22 AM
ATVracr's Avatar
A Nitrous jet size of .042" or 1.0668mm should produce:
637.31 HP with 8 port(s)
Actual HP to the wheels: 541.71 HP
Damn !!
Old Oct 27, 2008 | 12:59 PM
gator's 99TA's Avatar
Damn !!
no wonder why greg's cars always fly on the nitrous ! lol.
Old Oct 27, 2008 | 02:02 PM
ChevPower's Avatar
Damn !!
Nos says 40 is a 400 and it doesnt matter what n20 jet is the power comes from the fuel, I'll try a 40f 42N and see where it goes from there.
Old Oct 27, 2008 | 02:07 PM
ChevPower's Avatar
Also This is the first time i have used a progressive and i havent yet ran the noids at 100% so my question is how good are the controllers when we are pulsing the noids? Can the controller keep the AFR close when not at 100%?
During all the runs so far we have only brought the controller upto 50% of the 400.
Old Oct 27, 2008 | 02:09 PM
ChevPower's Avatar
**** my **** is slow if what he said is true lol But hey i'm doing good at keeping it to gether right? lol
Old Oct 27, 2008 | 02:39 PM
ATVracr's Avatar
But everyone runs different fuel pressures so the one constant thing you can measure is the N20 jet.
I use 45 psi of fuel pressure so my fuel jet is less than 1/2 of yours so does that mean I would only have a 200 shot on it?
Just messin with ya.
Old Oct 27, 2008 | 06:59 PM
LS1Queen's Avatar
LOL I should have said the amount of fuel rather than the fuel jet lol But i understand what your saying.
The next time i run it a plan on a tune up like this
40/42 at 5.5 psi flowing pressure
#10 plug
12* of timming
25% of the shot ramp to 60% in 2.5 sec
Maybe this will get the AFR above 10.1
EDIT... This is Chevpower
Old Oct 27, 2008 | 07:14 PM
next's Avatar
You have got to get the power in a lot sooner. I know you are just testing but if you ain't throwing it down in the 60' you ain't gonna ET.
Old Oct 27, 2008 | 07:19 PM
next's Avatar
I never used a progressive to control the entire hit. Only real value I ever got out of one was to put a couple tenths delay before the full hit. Others may have a different experience.
You should just change jets if you are only wanting 50%. That's a lot of risk I would think pulsing the entire track.
Old Oct 27, 2008 | 07:26 PM
ATVracr's Avatar
I was thinking the same thing and agree 100%.
Old Oct 27, 2008 | 07:29 PM
ChevPower's Avatar
I would love to put more power down faster but the car will not hook if i do.
I have about 20 passes where the front end was in the air when the power came in and it blew them off. I have been working with the car everyweek and so far 25% ramp in about 2.0 sec seems to be the only way to get it down the track.
We have ran at BMP, OSW and LMP allthree tracks same results. I am thinking or hoping that its just a hot track and radial thing and cooler weather will fix this lol
Old Oct 27, 2008 | 07:33 PM
ChevPower's Avatar
It is about a 2hour job to change the jets witch is why i wanted to jet it at 400 and pull it back with the controller while Paula was driving but if its going to be an issue i'll jet it back. Cant have her spraying a 400 every pass lol
