How Many Tenths Do You Drop in the 1/4 mile with a 150 shot
#43
Try installing the NANO system. It's good for another .2-.4 tenths, and you get every drop from the bottle. I haven't had a chance to run the NX with the new 382, but on motor, Orr89rocz and I run very similar N/A times. I can't wait 'til next year to let 'er rip. I bought the FJO ramp-up system for the NX kit. I will launch at 50HP and ramp up to 200HP and see what happens. Who wants a fairly new NX blanket system?
#44
What are you using for rear and tires? if you got some good DOT type slicks they should hook well so you can give it 125-150 off the line. Should ride out
#51
last night I dropped 1 second and gained 9mph roughly....funny part is the bottle was only at 700psi and my system was turning on anf off a few times because the fuel rpessure was right at the set limit of the safetyswitch...hehe...bad night...bad planning. hard to keep a bottle warm in 40 degree air..
#52
#58
11.52 @ 119.9 mph on motor (LS1 A4 Corvette with cam and all the bolt-ons)
Added the 150 shot and went 10.49 @ 129.9 mph.
That was with the nitrous shutting off a little before the traps as I had the shut-off set for 6200 rpm. I just raised the shut off RPM another 200 rpm. Should pick me up a touch more, I hope. Going back on the 20th of December so I won't know until then.
Here is the time slip if anyone is interested.
#59
I run a 02z28 A4... Only only thing I have done is lid, tune, and the juice...
I spray 150 shot..
stock the car ran: 13.3... dont remember speed....
on the juice, car runs 12.3 @ 115
that is a 2.0 60ft.. I am on street tires so I can not get it to grip out the hole...
in 2nd and 3rd the car ******* flies.... but in 1st I am spending more time holding it to the ground..... If I were to stick some DR's, I am sure I could get into the 11's
I spray 150 shot..
