What do i need to do to my engine to make it rady for nos
Old Sep 16, 2003 | 05:50 PM
j4nash's Avatar
Default What do i need to do to my engine to make it rady for nos
What do i need to do to my engine to make it ready for nos. I have a SS Truck with the 6.0.
Old Sep 17, 2003 | 07:54 PM
j4nash's Avatar
Default Re: What do i need to do to my engine to make it rady for nos
do i need to put new heads and pistons on ???
Old Sep 18, 2003 | 09:44 PM
j4nash's Avatar
Come on i know someone has to know something
Old Sep 18, 2003 | 10:48 PM
JESSIE's Avatar
Not much, I would changed the plugs and run a colder plug. The rest is on you and how much you want to spray. The motor will handle probably a 125 shot no problem. Just want to make sure that you buy a quality kit and install it properly. If this is your first time messing with nitrous. I would recommend getting help from someone that has experience. Main thing to remember is that you need fuel so I would also invest in an air fuel ratio gauge. Also you will want to get a window switch and a fuel pressure safety switch. As far as your engine is concerned you don't have to do anything to it if you plan on going less than 125.
Old Sep 19, 2003 | 12:40 AM
BLUE01Z-28's Avatar
put some tr6's in that thing and run the ss out of it lol
good luck man
