9.5 cr blower motor on spray ??????
Old 11-30-2008 | 04:34 PM
kngkahious's Avatar
Default 9.5 cr blower motor on spray ??????
i'm building a little at a time and am getting a blower motor built . still talking everything over with the shop on spec's. but i was curious what the outcome would be. i know n20 like's high comp so i was curious if the rating would stay the same. if i spray a 150 on it will it still be enough for 150 rwhp or 200 for 200 . i was wanting to spray it while i was comeing up with the money to put on a blower.
Old 11-30-2008 | 06:12 PM
RedTtop6spd's Avatar
Nitrous works on low compression as well. You should see around the same numbers, but it will really depend on your entire package, not just the CR.
Old 11-30-2008 | 09:58 PM
kngkahious's Avatar
i did'nt think it would really matter. just did'nt know if i sprayed it if it would make a difference. the motor will be built so i can spray the ***** off it anyway.
Old 12-01-2008 | 12:55 PM
Spray away and be safe about it.
Old 12-01-2008 | 09:03 PM
TARZAN's Avatar
Nitrous does like compression, but low compression with the right combo can see SERIOUS gains on some relatively small shots
-Will
