Window switch bypass
Old Dec 6, 2008 | 08:40 AM
blackz6sp's Avatar
Default Window switch bypass
Anybody know of a way to bypass my window switch, maybe on a toggle? I have a msd window switch, I don't spray through the shifts, and I'm windin out 3rd gear so I'm out of rpm with the window switch. Any help would be great.
Old Dec 8, 2008 | 10:19 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
please give me a call so I can go over a few things with you....I also want to make sure exactly what you are wanting, as there are a couple ways to do it.
Old Dec 8, 2008 | 03:28 PM
jimmyblue's Avatar
Moderator
If you're winding it out then I'd think you have no
further need for power? What are you trying to
achieve?
I found a nice little horn button at the Zone which
I am going to mount to the little kick-pedestal where
the high beam switch ought to be (old school) for a
"go-pedal". Mine will be in series with the window
switch (need both situation & intention) but you
could simply parallel one with the window switch
for either-or. But you'd be going without the safety.
Old Dec 8, 2008 | 04:33 PM
blackz6sp's Avatar
Thanks I will give ya a buzz tom.
achieve?
What I'm tryin to do is use the nitrous all the way down the track, I can wind out 3rd gear a few hundred more rpms to keep it from shiftin to overdrive, but I won't have the spray the last few hundred rpm, so I'm just tryin to override the window switch at the end of 3rd.
Old Dec 8, 2008 | 04:36 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
sounds good....I have a couple ways we can do this.
