Harris Speed Works 90mm plate kit
Anyone run this kit? I might be buying one and was wondering if this is good/bad run of the mill.... Any problems know.... also what else i will need?
HSW Sudden Impact 90mm EFI Wet Nitrous Plate Kit (90mm LS1 F-Body)
HSW Sudden Impact 90mm EFI Wet Nitrous Plate Kit (90mm LS1 F-Body) Description: LS1 F-Body complete 90mm EFI Wet Nitrous Plate Kit. Features full 360 degree perimeter style spray pattern for less turbulent intake charge compared to single/multi port spray pattern plates; please follow this LINK for a video showing the perimeter style spray pattern. This kit comes complete, ready to be installed. All electrical connectors are weather tight (heat shrinkable) and includes full color installation manual. Fully adjustable from 25 HP - 150 HP.
Components are Anodized Aluminum & Stainless Steel. Please see below for detailed pictures.
Kit Component Construction: Anodized Aluminum & Stainless Steel.
Please Note: Jetting is rated at the Rear Wheels (RWHP).
Quantity
Kit Contents
1 10 Lb. HSW Nitrous Bottle (Black)
1Pair of S.S. Quick Disconnect Bottle Brackets
1PowerMax 3-Port N2O Solenoid (.125 Orifice)
1PowerMax 2-Port Fuel Solenoid (.250 Orifice)
1HSW 90mm EFI Wet Plate (Anodized Aluminum)
1Misc. Hardware for Plate Installation (Anodized Aluminum | Stainless Steel)
1 4AN Bottle Nut (Stainless Steel)
1 20” (Inches) Blue S.S. Braided Hose (Solenoid to Nozzle)
1 20” (Inches) Red S.S. Braided Hose (Solenoid to Nozzle)
1 20” (Inches) Red S.S. Braided Hose (Fuel Rail to Solenoid)
1 16’ (Feet) 4AN S.S. Braided Hose (Main Feed Line)
2Blue AN to NPT Fittings
2Red AN to NPT Fittings
1WOT (Micro) Activation Switch & Bracket
1Arming Switch
140 Amp Relay & Harness
1HSW Nitrous Pressure Gauge (Mounts directly on Nitrous Bottle)
1Set of Solenoid Brackets (Hardware Included)
1Electrical Pack (Wire & all Electrical Connectors (Weather Tight)
Quantity
Kit Contents
1Arming Switch
ok so i ended up getting it for 280 but thats still not to bad, he said it also has the purge kit and "hardline"?
what else would i need/be recomended?
will soon be getting a fast 90 yes, i know doin it backwards but i couldnt pass up that deal...
I beeen looking at the HSW website and like their ash tray switch, but it has two accesory switches, i would think a bottle heater for one but what would the second one be? Also i want a nitrous pressure guage in my a-pillar how hard will that be?
Gauges are pretty straight forward. I would recommend using the electric gauges over the mechanical.
thanks
nick
You can use the second one for anything you'd like. Line lock, bottle opener (use the switch that comes with the opener kit in place) are just a few examples.
thanks
nick
thanks
nick
I agree...It will cost a little bit more, but it's better than having another 20ft line of nitrous going through your car...wasteful!
thanks
nick
thanks
nick
anything i'm missing? Oh and can anyone point me in the direction of a thread of pics for nitro setups? I dont know where i want to put it yet...
