What RPM are you guys starting to spray at???
Old Dec 9, 2008 | 12:30 PM
Ruckus46Gt's Avatar
100 shot plus nano so like a 120 shot tech and hits at 2200 rpms. Car wetn 1.54 with lca and relocation brackets on a lowering spring and 11.0@123
Old Dec 9, 2008 | 12:35 PM
blakern's Avatar
I plan on setting mine @ 4000 at first, then working my way down to 3500 or maybe 3300 @ the track.
Old Dec 9, 2008 | 01:38 PM
Twin76mmTA's Avatar
Plan on leaving at 5500 with .032 jets then adding in a progressive .042 jets and shutting the .032's off.
gotta let the motor eat
Old Dec 9, 2008 | 03:18 PM
4bangermustang's Avatar
My first stage triggers as soon as the T/B button is let go of,
second stage comes in .5 seconds after starting 10% and goes to 100% 1 second after the second stage turns on.
Just installed the FJO and haven't tried it yet, but from just testing it after I wied it, seems pretty sweet.
Going to set it as much on as possible out the hole that the tires/susp can take, once I hit the limit, I'll use the second stage to slowly bring it in the rest.
Old Dec 9, 2008 | 04:30 PM
Midnight02's Avatar
I have a FJO Mini as well and I love it.
I am jetted for a 100 rwhp shot -- it sprays a 70% shot at 3,300 rpm and ramps up to 100% by 4,000 rpm. I spray until 6,400 and typically shift right around 6,500 - 6,600 rpm. Given that I'm a M6 with 550+ rwhp on a stock 10 bolt, the progressive controller is helpful in reducing the initial shock. Once I get the 9" rear installed and toss a good tire at it, I might ramp it up a bit quicker.
Old Dec 9, 2008 | 05:21 PM
rocket5979's Avatar
Originally Posted by jermstyle
I spray 150 at 3000... I think that if you need a progressive controller for a 100 shot then something else needs attention. Like suspension and or tires.
Just my .02
It isn't a matter of "needing" the progressive controller for the 100 shot. The reason I have the progressive controller is so that I can tune the way the shot hits (i.e. control traction for one). And if and when I decide to increase the shot I do not need to rewire another controller in there. I subscribe to the "do it right the first time" approach.
Old Dec 9, 2008 | 09:51 PM
domestic disturbance's Avatar
150 at 3k
Old Dec 9, 2008 | 11:12 PM
Strahley's Avatar
3k for mine
Old Dec 9, 2008 | 11:36 PM
krazy4's Avatar
I did 3500rpm when I had the kit on my car. That was all just timing with my foot though. Didn't have a window switch.
Old Dec 10, 2008 | 08:59 AM
adriangarcia404's Avatar
well i havent used juice yet but my father has and he has shot off the tree and well on his old ls1 i think i was using juice around 3000 rpm.
Old Dec 10, 2008 | 02:04 PM
RIP1976's Avatar
Launched @ 1450 let the gas "150 shot" come on @ 1800
Old Dec 10, 2008 | 02:11 PM
  #32
z28rob18's Avatar
was 100 shot spraying off the line.
will be 200 shot off the line. ill probably leave off the limiter or watever the track will take
