View Poll Results: Will it be worth it on a small shot?
Yes
58.33%
No
0
0%
75 shot is for Civics
41.67%
Voters: 24. You may not vote on this poll
NANO Poll
Old Dec 9, 2008 | 10:45 PM
jetlag's Avatar
Default NANO Poll
Most places I've read people are using NANO on bigger shots.
I am running a 100 dry shot right now with the HSW Interface. NANO suggests taking 20% of the nitrous off and leave fueling the same...
So...let's just say I use a 75rwhp jet with the 100shot fueling...1/4 mile gains? Yes or no
(The reason for jetting down instead of fueling up would be because I'm running a dry shot on stock injectors)
Old Dec 10, 2008 | 09:54 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
with a "dry" shot the PCM would handle the fueling for you..no need to change anything unless you are wanting to maitain the same power level. If you are not wanting to increase the power output of the nitrous system you will need to decrease the size of the nitrous jet.
The reason for this is when using the NANO you are flowing pure liquid nitrous through the jet.
Old Dec 10, 2008 | 10:01 AM
Nick@HSW's Avatar
Since you're using the Interface, your assumption is true. You will need to bump the nitrous jet down and run a slightly higher fuel setting on the Interface since you want to be cautious on the stock injectors. Nice thing with the Interface if you need it to compensate for the steady state bottle pressure up top, you can use the top end fueling feature to add fueling up in the RPM's.
Thanks!
Nick
Old Dec 10, 2008 | 10:02 AM
Nick@HSW's Avatar
Not true since he is using the Interface. If it was a conventional dry kit, then yes.
Nick
Old Dec 10, 2008 | 10:03 AM
z28rob18's Avatar
id say its worth it you'll be using all the nitrous in the bottle and have good bottle pressure alway. if u hav the money for it then do it!
Old Dec 10, 2008 | 10:06 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Nick
I missed that....thats what I get for speed reading the post...I will go sit in the corner .
Old Dec 10, 2008 | 10:20 AM
Nick@HSW's Avatar
lol don't forget the dunce cap.
Old Dec 10, 2008 | 10:31 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
that went to PRI with Dave and Chris
Old Dec 10, 2008 | 10:56 AM
camar0corey's Avatar
Sucks, I wanted to meat the Nitrous Outlet guys, no PRI for me this year.......
I'd say get the NANO just so you can use the whole bottle. I'm sure even on a small shot there is a pressure drop also, no?
Old Dec 10, 2008 | 11:07 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
yep...any shot size will see pressure drop.
Old Dec 10, 2008 | 01:31 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
For the guys voting in the poll please note that by stepping down to the "75" jet it will still make 90-100HP at the wheels.
Old Dec 10, 2008 | 04:42 PM
jetlag's Avatar
Thanks!
Nick
Nick, can you explain that part a little more... I've read something about that....not sure exactly but it was something like on a normal system the pressure drop would be ok with the stock tune, because of engine heat,causing a lean condition, dropping pressure making it richen back up, blah, blah blah, I don't know..you tell me..hah
But the good thing being that it will be from start to finish
Old Dec 13, 2008 | 12:27 AM
Robert56's Avatar
Exactly, you will be getting a tad richer with no NANO as you are losing pressure in your nitrous bottle and lower pressure equals a smaller quantity of nitrous flowing out of the jet as you progressively get deeper into your run. However, there is a fix for that also, the Interface can also lean the a/f ratio out on the top end, can go positive or negative fueling as an add on to your set a/f ratio.
Robert
Old Dec 16, 2008 | 09:49 AM
Nick@HSW's Avatar
haha sorry Matt I stopped watching this thread...I thought me and Ray de-railed it. Robert above me is correct. You would just use the top end fueling feature to add the additional fuel enrichment that normally doesn't occur without nano.
Nick
