View Poll Results: Purge in the Motor or Not..
Don't Mess With Texas
5
0.72%
Our state will kick your state's ass
37
5.34%
Republic of Texas
4
0.58%
Bigger Than Most Countries
10
1.44%
Lone Star State
2
0.29%
Got Oil?
0
0%
Home of the Fastest Dragstrips
4
0.58%
The Promised Land
5
0.72%
Home Of The Fast Cars And Beautiful Women
22
3.17%
Where Everything is BIGGER and BETTER
14
2.02%
350
0
0%
355
2
0.29%
360
1
0.14%
365
3
0.43%
370
0
0%
375
1
0.14%
380
2
0.29%
390
1
0.14%
395
2
0.29%
400
2
0.29%
405
0
0%
410
0
0%
415
0
0%
420
0
0%
425
1
0.14%
4GET IT
5
0.72%
NONE 4 U
0
0%
GET SUM
3
0.43%
GREGO 1
0
0%
GOTCHA
2
0.29%
1 BD TRK
6
0.87%
SEE YA
4
0.58%
98
2
0.29%
99
0
0%
00
4
0.58%
01
8
1.15%
02
24
3.46%
June 7th
16
2.31%
June 21st
8
1.15%
Fajitas
18
2.60%
Hamburgers and Hot Dogs
8
1.15%
Yes I use a solid lifter when checking piston to valve clearance.
5
0.72%
No I do not use a solid lifter when checking piston to valve clearance.I use a Hydraulic lifter and "checking" springs
3
0.43%
I do not check piston to valve clearance.
0
0%
July 19th
22
3.17%
August 2nd
11
1.59%
Acura 3.2TL
3
0.43%
04 Nissan Maxima
1
0.14%
Honda Accord
0
0%
Audi A4
3
0.43%
Toyota Camry
0
0%
Infiniti I35
2
0.29%
VW Passat
0
0%
Mazda 6
0
0%
Yes!
8
1.15%
No!
13
1.88%
I'll buy it off you right now!
2
0.29%
bright red WS6 convertible
27
3.90%
bright red 35th anniversary Camaro SS convertible
43
6.20%
Go For It?
11
1.59%
Don't Mess With It....
3
0.43%
F-body
44
6.35%
03 Cobra
12
1.73%
FM/5
15
2.16%
ARO
3
0.43%
38 special - They just happen to be my favorite band too.
0
0%
380 ACP - I'll plink you to death!
0
0%
9mm - I've got 15 in the mag and 1 in the spout, AND I'll use every last one!
11
1.59%
357 Magnum - Don't be messin', I'll break out the Wesson
2
0.29%
40 S&W - I'm hip, I'm happenin', I'm down.
12
1.73%
45 ACP - I maybe slow, but I'll knock you out!
18
2.60%
44 Magnum - Harry and I are buds.
0
0%
50 AE - I just hate it when rhinos ATTACK!
2
0.29%
<a href="http://groups.msn.com/ChevySilverado/newpics.msnw?action=ShowPhoto&amp;PhotoID=250" target="_blank">Stock Trim</a>
1
0.14%
<a href="http://groups.msn.com/ChevySilverado/newpics.msnw?action=ShowPhoto&amp;PhotoID=248" target="_blank">No Trim</a>
10
1.44%
<a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=2427586671&amp;cat egory=34204" target="_blank">55 Bel-Air Fabbed Trim</a>
0
0%
<a href="http://www.theptking.com/eshop/product.asp?intProdID=151" target="_blank">GMC Chrome Molding</a>
9
1.30%
Cam/intake/tune
2
0.29%
torque converter/ET streets (mostly street driving though, remember)
5
0.72%
1
5
0.72%
2
18
2.60%
3
1
0.14%
4
8
1.15%
Stock GM
5
0.72%
SLP Double Roller
0
0%
Rollmaster Single Roller
1
0.14%
Rollmaster Double Roller
2
0.29%
Cloyes Single Roller
1
0.14%
Comp Cams Double Roller
0
0%
IWIS Chain, Stock Sprockets
1
0.14%
Other, Specify in thread
0
0%
Keep the Grand Sport stripes
10
1.44%
Go with the Hot-Rod "shorter" hockey stripes
10
1.44%
Go with the Sprewell "longer" hockey stripes
13
1.88%
Preditor?
0
0%
LS1 Edit?
15
2.16%
Something else?
0
0%
yes
9
1.30%
no
8
1.15%
For your own entertainment
14
2.02%
To be faster than someone else
6
0.87%
To reach a goal
5
0.72%
1) an LS1 with Heads and Cam
21
3.03%
2) 2002-2004 Z06
1
0.14%
Yes
4
0.58%
No
6
0.87%
Voters: 693. You may not vote on this poll
Can you purge through the intake??
Old Sep 26, 2003 | 01:56 PM
LIL SS's Avatar
Moderator
Default Can you purge through the intake??
Old Sep 26, 2003 | 02:23 PM
Camaro_Zach's Avatar
Default Re: Can you purge through the intake??
this is a common practice. If you are doing it because you are tying to hide it, ok. but if its a track car, just get a purge. The ONLY reason you would want to purge into the motor is for a hidden kit. Otherwise its pointless.
Old Sep 26, 2003 | 03:18 PM
LIL SS's Avatar
Moderator
It gets used for both.. I don't like the idea of making it public knowledge on the street. The hood does not get lifted
Old Sep 28, 2003 | 07:05 PM
The Guy in MY 99TA's Avatar
I purge through the motor. I do it because it not only purges the nitrous system, it purges the fuel system too. I beleive its necessary to get the best results. I don't have a purge valve...... but the only reason I would have one would be to put on a show.
Josh S.
Old Sep 28, 2003 | 07:47 PM
OSR 1's Avatar
you dont purge thru the motor to hide anything you do it because it purges nos and fuel at the solonied .
we did it in the past on our big motors but it was to hard on parts
Old Sep 28, 2003 | 11:58 PM
maddboost's Avatar
I just dont recommend it cause its a pain on the motor but if its a race car what do you care if you blow it up every now and then.
LIL SS's Avatar
Moderator
What parts get hurt fast doing this? Is it safer with smaller shots (75-150 for example)??
Old Sep 29, 2003 | 12:22 AM
unit213's Avatar
Administrator
I used to purge into the motor. BIG name racers do it as well. You just give it a little tap, tap, tap-a-roo...not a big amount of spray/fuel.
Old Sep 29, 2003 | 07:25 AM
OSR 1's Avatar
ring lands
promod guys are getting away from doing it now to
Old Sep 29, 2003 | 05:42 PM
LIL SS's Avatar
Moderator
So is it any worse than spraying the whole 1/4 mile? I would think it is less harmful due to no load.. Am I wrong?
Old Sep 30, 2003 | 01:56 AM
ALPINE's Avatar
Out of curiusity, where are you purging exactly? Next to the n02 nosle?
Old Oct 1, 2003 | 03:16 PM
LIL SS's Avatar
Moderator
It would be purging N20 and Fuel through the TNT power ring just as if you were spraying. Wire a push button directly to the WOT switch.
Old Oct 3, 2003 | 02:16 AM
Big Mike's Avatar
I purge my motor through the intake, its the only way I purge.
Arm the nitrous, bring rpms to 3500 then press the purge button keeping your foot in the same place
on the gass pedal. I usually do this procedure twice before I stage.
Old Oct 3, 2003 | 04:14 PM
fastlif's Avatar
Are you guys talking about purging with a seperate button controlling a "purge" solenoid or activating the n2o as you would going down the track? If you are spraying into the motor fuel and n2o, I can't imagine it being hard on parts....If you are purging straight n2o into the motor with no fuel it will be hard on parts.
Old Oct 5, 2003 | 03:32 PM
I mean that I engage the nitrous system, spraying fuel and nitrous into the intake.
I don't see it beinge hard on parts really..... unless you spray it above 5,000 rpm.
Josh S.
Old Oct 5, 2003 | 06:13 PM
FrankSS's Avatar
thats how my friend does on his car with a 300 shot.
FrankSS's Avatar
thats how my friend does on his car with a 300 shot. right through the motor with no problems.
