window switch?
Old Dec 13, 2008 | 08:12 PM
eric01ss's Avatar
Default window switch?
how many of u stalled a4 guys or a3 run one?
if so why and if not why?
also how often do ya'll spray your car and do you do strret runs as well?
Old Dec 14, 2008 | 06:18 AM
NVR_SPDS's Avatar
I have a4k stall and A4, and i just picked up HSWs Microedge. Its a window switch, and then some.
I just wanted to take some of the strain off the trans, by not spraying through shifts and the Microedge has alot of other safety features built in.
Old Dec 14, 2008 | 06:53 AM
Mike@HSW's Avatar
nvr spds put it very well. The window switch feature will certainly help prolong the life of your drivetrain. You could even lockout first gear which can help with traction and also save your rear and tranny. microedge is packed with other safety features as well.
Old Dec 14, 2008 | 07:09 AM
Ruckus46Gt's Avatar
i run one on my car. I spray through shifts still though. My window switch is set at 2200-6000
Old Dec 14, 2008 | 09:07 AM
Chhh Chhh's Avatar
2200!!!!!!!!!!????!
Old Dec 14, 2008 | 05:49 PM
jetlag's Avatar
I run a single stage window switch from DynoTuneN2O, but only use the nitrous at the track.
Awhile ago I tried to spray a 100 shot on an empty street....yeah, I was all over the road spinning through all the gears.
Strahley's Avatar
I didn't last year, but I'll be running on this upcoming year
Reason being, I'm running a manual shift th350. Should my shifter not ratchet or if the cable fails or something, I won't have to worry about spraying on the limiter, since I plan on spraying through the shifts
Old Dec 14, 2008 | 06:19 PM
quickblade's Avatar
I am not stalled, and I do not run one..
Bought one and it was having alot of problems... was not engaging, blah blah blah etc..
So basically we pulled out HP tuners...
My shifts are tuned for me to spray from the hit of 1st gear all the way thru 3rd.....
But you are stalled so will probably make a big difference... I guess I will be having to re-tune if I get my 3200...
I overall like to hit the switch!!!! better then just mashing the gas... Plus I dont have a m6 so it makes me feel like I am doing something more then just hitting the gas pedal and driving.. LOL
but that is just me.....
Old Dec 14, 2008 | 08:12 PM
Ruckus46Gt's Avatar
Originally Posted by Chhh Chhh
2200!!!!!!!!!!????!
yup whats wrong ?
Old Dec 15, 2008 | 07:39 AM
built408's Avatar
2200!!!!!!!!!!????!
With a loose converter that flashes high, you can spray that low. I spray from about the same RPM.
Old Dec 15, 2008 | 09:59 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I would not run a nitrous kit without one.
