Need help with NOS jets
Old Dec 14, 2008 | 01:50 AM
Pate_2008's Avatar
Default Need help with NOS jets
Ok i have a the fogger nozzle that has the fuel and nos going into it and its a nos brand. I do not know anything about jets and i am needed some 125 jets could someone please tell me what i need to get like what numbers they are or what i have no clue thanks guys.
Old Dec 14, 2008 | 01:56 AM
Pate_2008's Avatar
its just a universal wet kit NOS brand and i need some 125 jets and the numbers for them please or a link to the exact ones that i need thanks ! !
Old Dec 14, 2008 | 11:35 AM
Pate_2008's Avatar
anyone ?
Old Dec 14, 2008 | 03:21 PM
NVR_SPDS's Avatar
Have you checked the stickys? i know there are some jet charts up there in the everything nitrous related one.
Old Dec 14, 2008 | 04:18 PM
Pate_2008's Avatar
ya i have looked and it doesn't have anything about it so I don't know what to look for !
Old Dec 14, 2008 | 04:30 PM
Pate_2008's Avatar
this is the spray nozzle that i have http://www.holley.com/13700RNOS.asp. I need to know what jets will work for this for a 125 shot thanks.
Old Dec 14, 2008 | 04:36 PM
quickblade's Avatar
its in the everything related to nitrous sticky at the top of this page..
but here you go..
NOS jetting 5168 kit wet for LS1 RWHP RATED 900-1000psi rated
single jet plate system
75HP 41N 28F
100HP 51N 31F
125HP 55N 35F
150HP 63N 38F
and here is a calculator
http://www.robietherobot.com/NitrousJetCalculator.htm
Old Dec 14, 2008 | 05:29 PM
Pate_2008's Avatar
ya but thats the plate system right ? not for the nozzle is it the same will it work ? thats my questions I saw that on on there.
Old Dec 14, 2008 | 06:17 PM
quickblade's Avatar
did you use the calculator... When you plug the numbers in there it comes up almost identical as the plate system...
a little different, which I will think the plate system will have a closer exact number as to what HP you will get compared to a nozzle...
But the calculator works... I used it for mine.... It appears to be correct...
You will have to put in the numbers and see where it gets you...
Old Dec 14, 2008 | 10:41 PM
Pate_2008's Avatar
ok i get that i need a .035 and a .055 now where can i get these i can't seem to find the smaller ones looked on e-bay and some other sites thanks guys for the help.
Old Dec 14, 2008 | 10:47 PM
Pate_2008's Avatar
ok i found them on summit now, thanks alot guys for all the help
Old Dec 15, 2008 | 01:40 AM
Pate_2008's Avatar
ok so i found the manual for my nos system online and it has the jettings wrote down and here they are
40/28 = 75
51/34= 100
65/38= 125 and these were at 43 psi of fuel pressure
So i am trying to achieve a 125hp shot and so i put .065 in the calculator with a fuel pressure of 43 and the fuel jet is correct but the hp says 190 and 162 to the ground now I can't get this figured out. but the combo with the 51/34 comes out to be 100 ! I am so confued on what jets to get to get a 125 shot ! AHH ! Now when they say 125 shot thats flywheel correct ? So ya i just don't know what jets to get thanks for the help !
Old Dec 15, 2008 | 11:13 AM
LS1BLKSS's Avatar
Banned Village Idiot
make sure you get the NOS jets... i tried to use one of the NOS jets for my ZEX kit and it didn't work
Old Dec 15, 2008 | 02:51 PM
Pate_2008's Avatar
ok thanks alot i called nos and they said to use the 65/38 for the 125 shot because thats what it comes with and he said that the calculator isn't a real life tested on that set up so thats why its off. Thanks guys.
