where is your bottle mounted
Old Dec 14, 2008 | 07:53 PM
02 T/A 984's Avatar
Default where is your bottle mounted
setting up a nitrous kit and i dont want to put my bottle between the back two seats like most do for the simple fact i have a set of twin boys who are 3 and they will mess with it i need a different place to mount it
Old Dec 14, 2008 | 08:10 PM
Grifter's Avatar
Search, there's a lot of threads about this. Mounting the bottle in the spare tire well is a common location also.
Old Dec 14, 2008 | 08:33 PM
Mike@HSW's Avatar
if you dont use the hump between the seats you'll really have two other options. Most popular seems to be hidden in the spare tire well
The other option will be above the gas tank. If you dont have t-tops or dont care about having a place to put them, then you can mount it there.
Old Dec 14, 2008 | 08:36 PM
evilbeef54's Avatar
yup, wheel well
Old Dec 14, 2008 | 10:04 PM
BayAreaSS's Avatar
I like having my bottle in the th spare tire area. Out of sight out of mind
Old Dec 14, 2008 | 10:14 PM
STANG KILLA SS 2's Avatar
where the rear passenger seat was. i can reach the valve from the drivers seat easily.
Old Dec 15, 2008 | 02:07 AM
PONTIAC SLP's Avatar
here is mine i mounted the bottle in sexy place looooool also people can see the bottle outside in the street
Old Dec 15, 2008 | 02:31 AM
Ruckus46Gt's Avatar
Old Dec 15, 2008 | 12:56 PM
streetassasin's Avatar
Old Dec 15, 2008 | 04:17 PM
kharmichead's Avatar
I have mine mounted on the hump between back seats with the HSW bottle bracket. Pull the 2 pins and the bottle comes right out and I tuck the line behind the seat. The bracket that stay in the car is barley noticeable. I have 2 girls that have to ride back there so I need the room also. Besides, you don't want to ride around with a bottle all the time, especially in hot climates.
Old Dec 15, 2008 | 05:05 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'd like to put mine above the gas tank for space reasons, but I'm going to end up putting them on the hump between the rear seats. It gets way too hot down here to have them sitting some where like that in the sun all day.
Old Dec 15, 2008 | 06:55 PM
navyblueSS's Avatar
I have mine in the spare tire well. Makes for a very clean install.
Old Dec 15, 2008 | 07:11 PM
Ruckus46Gt's Avatar
why not I do all the time in AZ, it only hits 118 or so out here though
Old Dec 15, 2008 | 08:14 PM
Strahley's Avatar
In the hump between where the back seats used to be. Best spot ever
Old Dec 15, 2008 | 08:23 PM
ZZebes's Avatar
Old Dec 15, 2008 | 09:08 PM
TJ's Avatar
TJ
Old Dec 16, 2008 | 10:13 AM
nahasapeemapetalon's Avatar
I had mine hidden behind both seats covered with black blankets, never once did the track officials see them. Nor the stuff under the hood.
I just got a cage installed, and removed my rear seats, I am going to try mount them there angling toward the tunnel. I love those billet mounts but for two bottles it gets spendy.
Old Dec 16, 2008 | 12:37 PM
Because it could blow the disc out and then you'd have no nitrous. I had a bottle blow a disc that was sitting in my trailer and outside temp was only about 100 degrees. And even if it doesn't blow check your pressure gauge when it's been sitting in the car in 118 degree day, it ain't between 950-1050 unless it's about empty. It could be high enough to not even open your solenoids. When it's a hot day at the races I usually have to ice the bottle down between rounds to keep it around 1000.
#2 reason is some cops could be jerks and ticket you in some places since it's illegal for street use.
#3 reason is if it's in plain site why give a criminal another reason to bash your windows in and take something?
Old Dec 17, 2008 | 10:55 PM
DopdBrd's Avatar
Passengers schmassengers....who needs em
Old Dec 18, 2008 | 01:04 AM
99_Z_155's Avatar
matt, do you have any more pics of the first install there? the one with the billet bracket in the spare well?
