torquer v.3+100 shot =?
Old Dec 16, 2008 | 08:05 PM
WALK NASTY984's Avatar
Default torquer v.3+100 shot =?
just wondering if cammed ls1 with torquer v.3 will work good with nitrous
Old Dec 16, 2008 | 08:42 PM
Superman09's Avatar
LS1Tech Sponsor
my buddy Jon, pHenomIC on here, runs it with a 75 shot. I'm sure he'll chime in!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Dec 16, 2008 | 09:47 PM
c0ncEpT's Avatar
Word on the street is he runs a little more than a 75 shot
Old Dec 16, 2008 | 11:36 PM
ABQ99TA's Avatar
I'm about to run a 125 shot with it, I can't wait. I know someone that runs a 150 on it and it runs very well. So you should be fine.
Old Dec 17, 2008 | 06:16 AM
Mike@HSW's Avatar
I would pick up a full kit from Texas Speed
http://www.texas-speed.com/shop/item...d=174&catid=49
Since you DD your car i would go with something like a 233/239, and i probably wouldnt go bigger then that. if you get the v3 you'll need to run a dual valve spring kit that costs much more. this makes for a nice nitrous cam, although it really doesnt matter too much when spraying in the 100-125 shot range.
Old Dec 17, 2008 | 06:26 AM
2001z's Avatar
are you an auto or manual? might not want to go that big if your convertor is stock or just get a bigger convertor.
Old Dec 17, 2008 | 06:54 AM
Mike@HSW's Avatar
he's got an M6 so he'll be ok on that. clutch upgrade will most certainly be necessary if he is stock
