Need Inexpensive Progressive Controller
Old Dec 17, 2008 | 02:56 PM
Robert56's Avatar
Default Need Inexpensive Progressive Controller
I am looking for an add on progressive controller like the HSW Angle. The only problem with using the Angle is that it's for small load solenoids only. I already have the MicroEdge and Interface. The Interface can now allow us to use a progressive hit on the dry kits, yes progressing the injectors. (will work for standard kits too)
However, don't try this unless your Interface was shipped after Sept '08, and you can send your current Interface back for upgrading. Anyway, i was hoping that there was another add on progressive control box out there that just has the progressive feature and not much more?
Robert
Old Dec 19, 2008 | 10:03 PM
Reaper SS's Avatar
I've used the FJO with good sucess but it does need a laptop to program it.
I believe it will control the larger load noids.
Old Dec 20, 2008 | 01:25 AM
myfast70's Avatar
Why not just use the Angle to toggle relay's instead of the solenoids. That way you have a very minimal investment. I've got the NOS mini progressive on my '70 but I've only had to use it for its window features so far. It is a pretty basic controller. The FJO has a lot more control but as mentioned above you need a laptop for programming.
Old Dec 20, 2008 | 12:34 PM
Gimp98TNT's Avatar
I run a mini FJO box, It works with the bigger noids plus it can activate a 2nd stage also.
Old Dec 20, 2008 | 01:18 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
If I remember correctly there is a guy in the for sale section selling a NX maximizer for $100. I think it's the older one, but you could search for it.
EDIT: https://ls1tech.com/forums/lsx-parts...ace-parts.html
Old Dec 20, 2008 | 01:48 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Old Dec 20, 2008 | 03:40 PM
Robert56's Avatar
Originally Posted by NXRICKY
Ricky which one is that? That's prob what i am looking for. i want an add on driver box that will work with my existing MicroEdge and Interface, or at least a controller that I can through into the mix.
I know the FJO progressive will work in place of the MicroEdge and have helped set one up, but am keeping the current MicroEdge.
Robert
Old Dec 20, 2008 | 03:44 PM
Robert56's Avatar
Hmmm... Interesting I never thought about that? Wonder if the low amp side can take progressing or the many on/off actions. I have used the low amp side for triggering stages and ended up going another route due to it not working all the time so am skepical.
Robert
Old Dec 20, 2008 | 03:55 PM
ShiznityZ28's Avatar
Robert atv has a fjo progressor and an fjo window switch.
Old Dec 21, 2008 | 01:19 PM
NXRICKY's Avatar
Robert
Dynotune and Nitrous Outlet have them. I think 149.00. Link for some instrucitons.
Unit is simple only 4 dials and 4 wires to hook up.
Cycling a relay to make a solenoid pulse is not a good idea. Relays are slow and to designed to be cycled like that.
Old Dec 21, 2008 | 07:22 PM
Robert56's Avatar
Yea i found out the hard way on the relays and why it quite working after a period of time, lol.
Robert
Old Dec 21, 2008 | 08:41 PM
VH5150's Avatar
Dynojet Fan
robert i have an old nx maximizer.... the 4 button one, no laptop needed... shoot me a pm and ill sell it chaep...
part number 15963
Old Dec 22, 2008 | 02:54 PM
Robert56's Avatar
part number 15963
Can I use this as an add on to my current electronics? that's what i am looking for, as I don't need a full controller, just the progressive capabilities. I tried to find it to look at the wiring but no luck. So far the trick product Ricky put up seems the best bet as looking briefly at the wiring I can simply tap it into the existing set-up/wiring I have? now if yours is wire-able so i can just use the progressive part then I would certainly be interested.
Robert
Old Dec 22, 2008 | 02:59 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Clean yo' PM box out....
