can i hide this n2o?
Old Sep 27, 2003 | 09:58 PM
Stone0fFire's Avatar
Default can i hide this n2o?
i want to run a 150 shot or so, what do i need to do to hide this from people that look under the hood? is there a system out there that will get this done? thanx
also, is it even safe to run a 150 shot on a stock system?
Old Sep 27, 2003 | 10:24 PM
Onyx Z's Avatar
Default Re: can i hide this n2o?
You could try the spider kit. It's either NOS or NX that makes it. It is a direct port injection that goes under the intake so no one will see any hint of the nitrous.
Ryan
Old Oct 3, 2003 | 05:35 PM
thanks, ill do a search
so um.. how much should i spray?
Old Oct 4, 2003 | 12:23 AM
DONAIMIAN's Avatar
Its a nos cheater kit if i remember right, but it wont fit betwene the intake and the valley cover. I asked this a while back. It might be doable with the new fast intake since its a 3 part design, but you would have to get your hands on one to tell if you could route it on the inside.
Old Oct 4, 2003 | 12:54 AM
Onyx Z's Avatar
The kit that goes under the intake will only fit with an LS6 valley cover. A friend of mine had it on his 02 Z so I know it will work.
I wouldnt spray anymore than a 150 shot on the stock fuel system.
Ryan
Old Oct 4, 2003 | 01:08 AM
Assassin's Avatar
your going to have a bitch to hide a wet kit, you could do the 100 dry kit from nos and hide it under the plate below the filter opening, and run the two lines into a plate below there, do u catch?, also hide the bottle in the spare tire area!
Old Oct 4, 2003 | 04:22 PM
do you think that this page is a good idea to go by?
http://joshker99.home.comcast.net/installpage.htm
so.. if i do this,
the most i can run is 100?
i was thinking i should try to run 150
