is it safe ?
Old Dec 17, 2008 | 06:14 PM
PONTIAC SLP's Avatar
Default is it safe ?
hi , if the bottle pressure is 850PSI and i'm spraying , is there any danger in this ? and what is the good pressure i should run with , i heared from many people they said 950-1000 , so what good pressure i should run with to give me good results
thanks , Mohammed.
Old Dec 17, 2008 | 06:57 PM
smokeum99ta's Avatar
That depends on the kit. Some kits use different bottle pressures therefore there jets will be different than other kits. So yes, there could some danger if 850 psi is not what your kit recommends.
Old Dec 17, 2008 | 09:55 PM
Nick@HSW's Avatar
a/f is pressure dependant on a wet system. so you really should be spraying at the recommended pressure to avoid any issues.
nick
Old Dec 18, 2008 | 04:17 AM
that system i use they recommended at 950PSI so thanks guys
Old Dec 18, 2008 | 11:47 AM
slmawi's Avatar
most heater kit come with pressure switch and Adjustable @ 950 psi
i have one and work great
Old Dec 18, 2008 | 06:07 PM
what is yours ?
Old Dec 18, 2008 | 07:03 PM
john563's Avatar
well when you get it sorted out and working,just make sure you make another vid racing more bikes o.k. lol
Old Dec 18, 2008 | 07:22 PM
loooool when i raced that bike the pressure was 900PSI or below i sprayed 100HP , i warmed the bottle by fire to 1000PSI but the weather so cold it comes down fast to 900PSI , i'll race many fast bikes till i purchase a new clutch with +200 shoots
Old Dec 19, 2008 | 04:31 AM
slmawi's Avatar
my heater is Harris Speed Works
switch on and bottle pressure 950psi all the time when switch go on
Old Dec 20, 2008 | 07:28 AM
sounds good ! thanks buddy
Old Dec 20, 2008 | 09:12 AM
JoeMama's GTO's Avatar
Please don't use fire to warm the bottle, unless someday you want to see a pressure drop to 0 psi in a fraction of a second.
Old Dec 20, 2008 | 09:18 AM
don't worry i have the gauge pressure
