blow DOWN TUBE what is NHRA legal post up pics of yours
Old 09-14-2008, 09:50 PM
dnkynrbk's Avatar
Default blow DOWN TUBE what is NHRA legal post up pics of yours
Getting ready to race at a track that does some hefty safty checks. How is your blowdown tube supposed to be to be legal. And post up some pics of yours. Also can you run a rubber hose off your tube and run it out thru a hole in your car?
Old 09-14-2008, 10:15 PM
jetlag's Avatar
Old 09-14-2008, 10:27 PM
dnkynrbk's Avatar
thats a sweet set up man.
Old 09-14-2008, 10:29 PM
suzookiegsxr's Avatar
Don't use rubber hose, 1200+psi is not for rubber. a metal purge line or braided hose would work but I don't think its certified.
Old 09-14-2008, 10:30 PM
jetlag's Avatar
Thanks,
I drilled through the cupholder because it is easier to patch up instead a hole in the middle of my carpet.
I'll just super glue a coke can to cover the hole or something.
Old 09-15-2008, 09:31 AM
ShiznityZ28's Avatar
No picls but ATv's setup is cool. kirkey seat holding the 15 lb bottle with the blow down tube being a braided line going straight down threw the floor threw hole in seat via bulk head fitting nitrous feed line is only 5' long. maybe he can post some pics.
Old 09-15-2008, 12:26 PM
DopdBrd's Avatar
I just made both of mine. -8AN stainless steel line with some -8AN fittings on both ends, then a bulkhead fitting going under the floorboard under the rear seats.
Old 09-15-2008, 05:57 PM
SSPerformance's Avatar
easyest way to
Old 09-15-2008, 08:05 PM
Nitro Dave's Nitrous Outlet's Avatar
The aluminum tube will pass. If you go to a braided hose it has to be bulkheaded to the floor. No rubber hoses..... Think safety..
We stock all the items to custom build a -8 braided blow down tube.
Dave
Old 09-16-2008, 06:24 PM
blk04z's Avatar
I have a braided hose to a bulk head and no track has ever giving me a problem
Old 09-17-2008, 11:16 AM
Race your car!
JL ws-6's Avatar
I put a -8 braided hose to a bulkhead thru the floor, no problems here either.
Old 09-17-2008, 01:22 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That sounds pretty cool. You should get him to post some pictures.
Old 09-17-2008, 03:30 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
Here is the kit we offer with braided line to give you another option
http://www.dynotunenitrous.com/store...p?idproduct=86
Dean
Old 09-17-2008, 09:38 PM
Mike101's Avatar
Can you run a 4an braided line as a blowdown tube and pass tech?
Old 09-18-2008, 11:24 AM
16again's Avatar
Dean
I have that hose. Had the NOS tube, just looked out of place. This one is a bit cleaner and secures to the floor. In my case it's the tub section on my C5 Corvette, just between the 2 exhaust pipes on the passenger side. The red is actually form a gasket that I put so as not to get any exhaust into the vehicle. It is cleaned up now.
Old 09-18-2008, 11:35 AM
Kelly.'s Avatar
you only need a blowdown tube if the bottle is in the passenger compartment right?
if you have a sealed truck (ie have the back seats still intact) then you shouldnt need one?
or have i been told wrong?
i like the idea of a braided line blowdown tube if i do need one.
Old 09-18-2008, 11:47 AM
5_02ls1's Avatar
i have a spare tire mounted bottle and i used an nos blowdown tube that goes through the grommet in the bottom of th spare tire well...
Old 09-18-2008, 12:32 PM
Race your car!
JL ws-6's Avatar
I "thought" it had to be a 8, but it may not matter.
I'd just do a -8 so that way there's no potential issue. Plus, if the bottle got up enough so it blows, the bottle is really hot and the nitrous is gonna be coming out really fast, I'd want that to be able to have a quick escape route.
Old 09-18-2008, 01:27 PM
transam69230's Avatar
That is correct, if it is sealed off from the passenger compartment you don't need a blowdown.
jcmeeks's Avatar
Remember that when you have a liquid or gas under high pressure and you release the pressure it gets really COLD, not hot. That's why you need a bottle heater
Quick Reply: blow DOWN TUBE what is NHRA legal post up pics of yours
