how to work the full throttle
Old Dec 17, 2008 | 08:13 PM
hnaskoct's Avatar
Default how to work the full throttle
i have 25*base of timing in my car what do i advance to get my timing at 29* and advanced across the board the 2 switches say base, wot,
Old Dec 17, 2008 | 08:52 PM
evilbeef54's Avatar
uh.....
what?
Old Dec 17, 2008 | 09:36 PM
jetlag's Avatar
Old Dec 17, 2008 | 10:05 PM
Nick@HSW's Avatar
Use the spark base dial to advance the timing throughout the entire RPM range. If using it with nitrous I would recommend retarding the timing while spraying.
Nick
Old Dec 17, 2008 | 10:24 PM
Robert56's Avatar
Damn, Nick is clairvoyant also, lol.
Robert
Old Dec 18, 2008 | 06:29 AM
Nick@HSW's Avatar
I get around...
Nick
Old Dec 18, 2008 | 01:20 PM
evilbeef54's Avatar
apparently
Old Dec 18, 2008 | 01:24 PM
Driftunit's Avatar
what is a spark base dail?
Old Dec 18, 2008 | 01:56 PM
Nick@HSW's Avatar
He's talking about the LS1 timing tuner.
Nick
Old Dec 18, 2008 | 02:21 PM
hnaskoct's Avatar
so whats the wot switch for, and im gonna spray 150 once i set the retard 6* will it pull the timing when the nitrous hits right..
Old Dec 18, 2008 | 02:36 PM
Nick@HSW's Avatar
Do you mean the WOT switch or WOT dial on the timing tuner?
The WOT dial on the timing tuner is used to add or subtract timing from 3000RPM and up. WOT switch on a nitrous is kit used to activate the nitrous kit only when the vehicle is wide open throttle (wot).
Nick
Old Dec 18, 2008 | 05:23 PM
hnaskoct's Avatar
Nick
oh ok i got it now so that wot dial is basically somewhat i window switch?
and the timing does get pulled when i spray it right
