conflicting info on NX jet sizing
Old 09-29-2003, 10:18 AM
bigSS's Avatar
Default conflicting info on NX jet sizing
What size jets do you guys use for your NX kit? Specifically for a 100shot and 150shot? Last night I couldn't find my NX jet chart sheet, so I cruised around on the message boards and found one guy said to use a 52 N20/33 Fuel pill for a 100shot. Well, I got home and found my sheet, and it says to use a 52/31 ... and it goes on to say that to use the 33 for a 150 shot. I guess I should just ask you guys what you find works best for a A/F ratio safe 100 shot and 150 shot. And if 52/31 is the correct jets, how much of a difference would a 52/33 make, because the car pulled hard with those jets (first time N20 user).
Also, not that I am anyone to doubt NX, but on the N20 pill size, your jumping from 52 to 62... whereas on the fuel size your only jumping from a 31 to a 33. Doesn't that seem like an awfully small jump? Your thoughts on that as well.
Thanks.
Old 09-29-2003, 10:34 AM
Nitro Dave's Nitrous Outlet's Avatar
Default Re: conflicting info on NX jet sizing
Alex,
Here are there most recent jet patterns for LS1.
N F
100-52-28
150-62-33
Old 09-30-2003, 12:57 PM
Ed Blown Vert's Avatar
I wish NX would make up there minds.
I have on my chart
100 52/31
150 62/33
I do run really rich on 52/31.
Old 09-30-2003, 04:43 PM
juiSSed1172's Avatar
Fuel jettings are just a rough estimate based off of fuel pressure anyways..
Not much diff between the 28 & 32, just needs tuning like any big mod....
Old 10-01-2003, 07:34 PM
Dano 00TA's Avatar
Yeah, nx is kinda lost on this? My jet chart states the following:
HP N20 FUEL
50 33 18
75 41 24
100 52 33
150 62 35
I never tried the 50 shot but the 75 gave me .7 in the 1/4 and ran great but the 100 shot jets I have caused problems running way too rich so I backed off to a 31 on the fuel jet and it ran alot better. So I guess all my fuel sizes are too rich?
Old 10-02-2003, 11:13 AM
bigSS's Avatar
LOL, great, so we have 3 different fuel jets that you supposed to use for a 100 shot.
BTW, someone mentioned fuel pressure. I'm running a racetronix kit (supposed increase in fuel pressure by about 3-6 psi), how will that change my fuel pill selection.
Old 10-02-2003, 08:45 PM
LS1TECH Sponsor
Racetronix's Avatar
Under WOT the return fuel volume should fall back within the regulator's grasp allowing for proper regulation at apx. 58PSI.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
