how many spray thru shift?
Old Dec 29, 2008 | 08:58 PM
eric01ss's Avatar
Default how many spray thru shift?
how many of u guys spray through the shift?
also how much are u spraying and how long has your tranny lasted?
also what tranny are u running?
Old Dec 29, 2008 | 09:12 PM
Ruckus46Gt's Avatar
I do, stock 4l60, 100 shot plus nano, 100 passes or so
Old Dec 29, 2008 | 09:13 PM
eric01ss's Avatar
thats crazy! i have people to just spray through the shift on my built 60e
Old Dec 29, 2008 | 09:34 PM
BOLO's Avatar
Most people I know at the track sprays through the shift, myself included.
Old Dec 29, 2008 | 09:47 PM
Ruckus46Gt's Avatar
id say throw a shift kit in though it will help it live longer
Old Dec 29, 2008 | 09:50 PM
eric01ss's Avatar
i have a brand new built 4l60e i should be fine
Old Dec 30, 2008 | 07:20 AM
streetassasin's Avatar
I dont, n2o off at 5700
Old Dec 30, 2008 | 10:21 AM
jetlag's Avatar
Not I.
Old Dec 30, 2008 | 11:08 AM
aksz71's Avatar
i do 125 shot ,4l60e 30 passes now
Old Dec 30, 2008 | 11:21 AM
yall are some brave people
Old Dec 30, 2008 | 11:50 AM
Chris@NitroDaves
Guest
Posts: n/a
Old Setup
4L60E , 200hp , 6months of pure abuse ( 4 track passes and god knows how many street races and just spraying it to spray it )
New Setup
TH400 , Built to withstand spraying through shifts
-Chris
Old Dec 30, 2008 | 12:14 PM
LS1 SPEED's Avatar
always have done so...never an issue.
4L60E's both stock and built
TH400
TH350
Old Dec 30, 2008 | 05:50 PM
16again's Avatar
I spray through my stock 4L60E Don't know how long it will stay together with the Nitrous but it has a few hundred 1/4 mile drag strip passes on just the motor.
Old Jan 4, 2009 | 04:07 PM
domestic disturbance's Avatar
id kick it out but it looks as if a lot of people are having decent luck spraying through shifts...
Old Jan 4, 2009 | 04:30 PM
fast377's Avatar
TH400
TH350
Same here. I never knew there was any other way. Seems kind of dumb to not spray through the shifts. Add a T56 to that list for me...and some ford trannys too.
Old Jan 4, 2009 | 04:56 PM
ALLMOTOR346CI's Avatar
I also spray thru the shifts level 3 built 4l60E 150shot over 200 passes atleast on a 100shot not including street races etc.
Old Jan 4, 2009 | 05:41 PM
97BlackLT1TA's Avatar
I do as well.
TH400
Old Jan 4, 2009 | 05:45 PM
kc533's Avatar
I'm assuming this is for the auto guys only? Reason being, is I don't see the need to spray through the shift on the T56, especially if you have a good controller for your nitrous.
Old Jan 4, 2009 | 06:48 PM
built408's Avatar
How would you spray thru the shift on a 6 speed? Please try it, and let me know how it goes...
Old Jan 4, 2009 | 09:01 PM
5_02ls1's Avatar
power shifting^^^^....my nitrous is on a wot switch...if you aint spraying thru the shifts you are leaving e/t and mph on the table...the kit iput onmy cobra had a window switch and i didnt like it so now its activated off awot switch only and the t.a has always been on a wot....
just get a good cooler on the 60e and dont do alot of hot lapping and it will last along time,spraying thru shifts...
