Victor Jr users inside please HELP!!!
Old Jan 11, 2009 | 06:06 PM
WS6 Canada's Avatar
Question Victor Jr users inside please HELP!!!
I am installing a Victor Jr. with an Arrons elbow and was wondering what you guys are doing with the vacume lines and that sensor in the back of the stock intake. How are you installing them on the Vic Jr.
Please post pics if you can.
I posted this here, because there are more nitrous guys using this like myself.
(spry bars plumbed in)
Thanks
CW
Old Jan 11, 2009 | 07:36 PM
jmill96Z's Avatar
MAP sensor on the side port, and brake booster off the big fitting on the back.
I'll post some pics shortly.
Old Jan 11, 2009 | 08:28 PM
383lt1impala's Avatar
I need this info also!
Old Jan 11, 2009 | 10:26 PM
Robert56's Avatar
Here's a little write up we did. It's kind of a how I did the install. You might be able to get some insight. However, everyone's take on particulars is what makes hot-rodding unique. So you may or may not get some ideas. Let me know if I can help should you run into a problem on your install as i have done a couple of them now.
Vic Jr Single Plain Install
here is a thread that a guy started (mrr223)on the Vic Jr and it ended up with some great info on exactlt what your doing. I think there are some great pictures, IIRC, addressing your questions specifically.
Vic Jr Info Thread
and here's one addressing elbows:
couldn't find it, lol, but if your really interested i will look again.
Robert
Old Jan 11, 2009 | 11:18 PM
WS6 Canada's Avatar
Thanks Robert!!!!!!!!!!!
Old Jan 12, 2009 | 12:42 PM
Mike@HSW's Avatar
Same thing as Jmillz here. MAP sensor goes in the side port and brake booster off the runner. If you are keeping your AC, run a t-fitting from the side port so you can run both the MAP and AC off of it.
Old Jan 12, 2009 | 01:24 PM
tripblackls1's Avatar
umm is this why my heater will only blow to the floor and not out of my vents??
btw sorry for the highjack
Old Jan 13, 2009 | 12:32 PM
Skinny's Avatar
Yep, that'll be it. All of the actuators for the AC doors are vacuum driven. Without the vacuum line hooked up, they won't move.
I T'd my MAP sensor into the brake booster line. I had a T in there from a former vacuum modulated tranny. I ran a hose from my LS6 valley cover through a PCV valve and into the port on the side of the intake so I had a functional PCV. I removed my AC, so I had no use for that vacuum line.
Old Jan 14, 2009 | 08:10 PM
Mike@HSW's Avatar
^^^ what he said....
Old Jan 16, 2009 | 12:19 AM
Nitro Dave's Nitrous Outlet's Avatar
There is a thread on here somewhere from whan I first put a Victor on my SS when they first hit the market. It shows step by step pics and the elbows we build. But if you look close we build a vacume black that bolted down and help the map sensor.
Dave
Old Jan 17, 2009 | 11:56 PM
Robert56's Avatar
Here's how I did mine. Relocated to the back intake bolt and on the vettes that is out of sight pretty much, then a vac tee was added from the auto parts store. pretty simple really.
Picture of MAP relocate
Robert
Old Jan 19, 2009 | 11:30 AM
Holy huge picture Robert!! lol
Old Jan 19, 2009 | 03:24 PM
Robert56's Avatar
LOL, yea that sucker was pretty big, fixed it, lol. One thing to point out, the bracket I used is the one supplied in the intake kit and they say to mount it on one of the carb studs, but that looks really cluttered like.
Robert
