How bad is it to run WOT with a......
Another words, if i get my car tuned to my 150 shot of nitrous with 108octane, coming from a seperate dedicated fuel system (or stand alone system), what would the car react like if I ran Wide Open Throttle N/A on the cars regular tank of gas which is 93octane? Remember, the car will be tuned for the 150 shot on 108gas.
Can't you have it tuned for N/A and the Nitrous situation? I think you can either flash your ECU with the appropriate tune for the appropriate situation. Probably some nitrous controller's that will let you have multiple tunes as well.
Probably a good bit of information already on here. Do a search and see if you can't come up with some similar situations.
Good luck!
What did you mean that I will see a drop???
As to the drop, Youll normally pull timing with nitrous which means less power N/A. the 2-4 we pulled out of mine didnt hurt it at all.
http://www.nitrousoutlet.com/catalog...roduct_id=3467
Dave
Dave
One last thing, where does that timing control module get connected too?? ...and how does the rev limiter work on this module??
With the Lingerfelter it plugs in between the coild packs. There is one wire that is hooked up at the controll box. The controll box has switches where you set the retard you are looking for. This unit also has a two step built in.
I was very impressed with how fast the install went.
Dave
