Best spot to get 12V switched at????
Installing a HSW Dry kit w/microedge and interface. I want to put Microedge in center console. Where are you guys tapping into a switched 12V?? What location are you going thru the firewall? Any pics or tips wouls help this nitrous
newbee!!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I ran all my wiring through a hole in the passenger side of the firewall. Take out your computer and you'll see a rubber grommet. Pull that out, drill/cut a hole in the grommet, run your wires through and put the grommet back in. The hole is down there pretty far so you'll have to kinda look for it.
Thanks Racer. Did ya'll run your feed line from the bootlr under the carpet or did you exit thru the hole behind the passenger seat then back in the engine bay???
