Which kit to use?
http://www.harrisspeedworks.com/shop...age=1&featured
http://www.harrisspeedworks.com/shop...cat=398&page=1
The plate offers superior distribution with 10 nitrous and 10 fuel discharge points spread around the full 360 degrees of the perimeter. It produces a conical spray pattern that reduces turbulance of the incoming air. It will flow all you will ever need.
Looking at the mod list you have planed you will defintly need a fuel system upgrade as well. You may look into the racetronix system. It will support up to 650 rear wheel hp.
http://www.nitrousoutlet.com/catalog...product_id=966
Since you plan on spraying in the range of 200 HP. You may end up needing more of a fuel upgrade than listed above. Watch the fuel pressure and if it starts to drop you will need to looking into one of our dedicated fuel systems.
I would suggest looking at our plate system. Our design is well known for delivering Big reliable horse power. Our plate system is the only efi plate on the market capable of flowing over 400 horse power. With that being said you will not hit a wall with what you have and you can grow with it. Let me know if I can help in any way.
Thanks
Dave
to the op.
coming from a nitrous guy without tons of cash and wanting the best flowing and functional kit both for performance and apperance, you simply cant beat nitrous outlet. there stuff might be a little bit more costly but, from 1st hand experience chris and grant over there treat you like family when you call their asking for advice, technical help or to add something to your kit.
so what im getting at, the best kit hands down is the n20 outlet plate, they have a 92mm plate, their bad *** cylinder head bracket and of course all the custom fittings and hose to really make your kit stand out. if you want ill pm you a pic of my setup that chris and grant set me up with, couldnt be happier, and when the guys at the track see n20 outlet on that plate instead of hsw, that says it all.
good luck with your decision, i have personally purchased from both company's both have their strengths but from personal experience with both the hsw plate and n20 outlet plate, and n20 outlets plates craftsmanship is second to none.
again big thanks to chris and grant, and ray for setting me up with all the wiring diagrams per pm very quickly for my exact setup.
Dave
to the op.
Dave
Nick
It might not be the "smartest" thing to do as you so eliquently put it, but when you are building a car for certain classes that dont allow foggers/direct ports this is your only option.
As said above, Nitrous Outlet has some of THE best customer service in the industry!!
We would not suggest using anyone elses plate other than ours for Horse power levels over 200 or more.
Dave
Dave
In regards to the forthcoming pissing match...I believe Mike was just correcting your statement in regards to being the only plate on the market to flow in excess of your numbers which was obviously incorrect.
Nick
Nick
