Should I consider my elevation??
I live in Wyoming, where the elevation is 6109 ft. I bought a '99 T/A in July and am going to put a dry nitrous kit on it in the next couple months. My question is, since the elevation is so high, will i still be able to safely run a 100 shot on a stock everything except a FTRA and longtube headers? Or, should I just run something smaller? Sorry if this had been posted and I couldn't find it, I've read sticky's galore looking for it...maybe i'm an idiot..i won't rule that out!! LOL
I live in Albuquerque, elevation is 5200 ft +/-. 100 shot will be no problem at your elevation, you will be down at least 100 hp from what most at sea level see.
But to answer the OP's question you'll be better off with the altitude. The higher the altitude you don't have to run as high an octane gas, pull as much timing or you can run a larger shot. You'll be safe with a 100, I shot 125 with pump gas and stock tune and our altitude is close to yours.
I guess we have it lucky down here at a whopping 300ft.
