single vs dual stage on a 200 shot
Also, will a walboro intank pump be enough if the motor makes 410rwhp and then you add the 200?
thanks again.
If you have the hotwire kit you might be ok. I have seen them max out around 600-650 rwhp.
You just have to play with it. If your can can take 200 off the hit, it would be a whole lot cheaper to keep it in one kit.
Robert
If you have a built 346 I see no reason why the motor can not take 200. I have hit stock motors out of the hole on 200.
Adding a second stage or simply adding a progressive to what you have is nother option if traction is an issue.
Dave
