MSD RPM Window Switch - Burned out?
Old Jan 19, 2009 | 01:38 PM
maggiemike's Avatar
Default MSD RPM Window Switch - Burned out?
Has anyone had any problems with the MSD digital rpm window switch crapping out?
Old Jan 19, 2009 | 03:31 PM
Nick@HSW's Avatar
For the most part I haven't heard anything about them failing. I forget who it was but someone that posts on here a lot kept having issues. He swapped it out for our microedge controller and it solved his problems. Let me know if you need any help verifying if its working or not. Thanks.
Nick
Old Jan 19, 2009 | 03:35 PM
maggiemike's Avatar
hey Nick, thanks for the reply. if you have any suggestion on how I can test it I'm all ears. I'm thinking I'll probably just bypass it and test it, that should be the easiest I think. It seems to me it has gotten worse over time, slowly failing. I've had some issues with my system since I got the car. I've replaced everything except for the window switch and the wot switch.
Old Jan 19, 2009 | 03:46 PM
Nick@HSW's Avatar
Shot you over a PM.
Nick
