6-Speed Nitrous Guys
Old Jan 29, 2009 | 10:27 AM
1BADAIR's Avatar
Originally Posted by ls2 bait
how did u do this? i have a synergy two step but i cant use it when the n2o is armed because it activates the n2o when i go wot.
does the synergy have an output wire?
most use a shut down relay to disable the n20
here is a diagram how to do it with the lpe unit
http://www.lingenfelter.com/document...tionsv3.02.pdf
Old Jan 29, 2009 | 10:37 AM
Midnight02's Avatar
I went with a FJO Mini Controller -- it works as a WOT switch, window switch and a progressive controller.
As for timing, I'm simply running a N2O tune (pulled timing)....knocked off about 8 - 10 rwhp on my N/A setup, however at least now I'm good to go anytime I spray it.
Old Jan 29, 2009 | 08:42 PM
ls2 bait's Avatar
i dont know...can you tell me
the top one is the synergy diagram and the bottom is the n2o.
Old Jan 30, 2009 | 12:24 AM
LS2Camaro's Avatar
Window switch to kick on at 3500rpm and WOT switch to make sure I am at full throttle before it even thinks of activating. It was not always like this as I had neither on my Viper and was running a 200 shot constantly. Luckily nothing happened and I ended up bringing the shot down to a 150 and added the WOT and window switch and had it tuned. Now I GO and can feel safer about running the nitrous and not have to worry about blowing up a V10.
Old Jan 30, 2009 | 08:25 AM
SPEEDYws6's Avatar
That is why I found a used Harlan 2 step. It has an output wire I use to control a relay wich opens the control side of my nitrous curcuit.
There are ways to do it with your setup. I'm not sure if the clutch swith can be used to control a relay without causing other issues. (i dont have a diagram to look at) If it can I would use it to control a seperate relay.
Old Jan 30, 2009 | 08:37 AM
Grifter's Avatar
How do you guys have your MicroEdge's set up? I am going to need to know for when I install my kit.
Old Jan 30, 2009 | 08:42 AM
SuperSlow02's Avatar
Youll have to send your box in to synergy to have them rewire it. Call or email peter at synergy and he can hook you up. I havnt had the time to take my box out and send it it yet, but since I launch under redline I dont need to be WOT till I dump the clutch, so not much of a priority for me.
Old Jan 30, 2009 | 08:45 AM
Originally Posted by Ihasfip
I have a Mallory Digital VI for my window switch, and rev limiter and it pulls 4 degrees of timing. Then a wide open throttle switch and a Nitro Dave's switch panel. I have 2 degrees taken out of my tune as well. And I guess I am kinda a noob too, what is this two step all about?
D
Let me rephrase this. I know what a two step rev limiter is . But how and why would you use it in conjunction with nitrous?
You would use because you dont have to worry about getting to your launch RPM...honestly all there is to it, I havnt launched off mine yet at the track So i dont know if it improves anything other then consitancy
Old Jan 30, 2009 | 09:29 AM
Ihasfip's Avatar
Yea I knew you could use it to make more consistent launches but that seemed like about all it was good for?
D
Old Jan 30, 2009 | 09:54 AM
ls2 bait's Avatar
ya the heck with that. i spent too much time extending all the wires to run the box in the cabin im not cutting them all out. this thing should have a plug on it.
