im on the juice
Old Feb 1, 2009 | 07:33 PM
LTLRDSS's Avatar
Default im on the juice
i got my nitro daves plate kit on today and will finish the wiring tomorrow and hopefully test it out
my question is, is it ok just to test the system out with a 25 or 50 shot on a NA tune, i belive im advance at 32*
once i know the system works ill be going to get it retuned or just get the timing where it sould be for a 100shot
Old Feb 1, 2009 | 07:39 PM
01SOMZ28's Avatar
i'd just throw the 100shot in to start with, when i finished installing my nitrous i started with a 100shot. Then me an some friends hit up a quiet road and i flipped the switch an went WOT. I was really impressed! Then a month after that i put the 150shot in and that was deffinately more impressive. Just put the 100shot in, you'll be fine.
Old Feb 1, 2009 | 08:11 PM
69_YENKO's Avatar
being already at 32* i dont think i would recommend testing with a 100shot. a 25/50 might be ok, i would just pull the lines off the plate, after the noids and test that the solenoids are opening up that way, you don't actually need to spray the motor to test that its working. your timing is up there, i would try to tune it before you spray it.
Old Feb 1, 2009 | 08:18 PM
LTLRDSS's Avatar
thats what i thought, i know im up there at 32. ill just disconect the lines from the plate and hit it in the garage
Old Feb 1, 2009 | 08:31 PM
Mike@HSW's Avatar
I agree, thats a much better way of testing your system to make sure everything is functioning correctly. I would definitely not suggest running a 100 shot with timing advanced that far.
Old Feb 1, 2009 | 09:27 PM
01SOMZ28's Avatar
i wouldnt suggest the 100shot like i said before, i forgot you said your timing was advanced that far when i was typing that reply
