Relays?
Old Feb 2, 2009 | 02:15 PM
jdiddyws6's Avatar
Default Relays?
I have just a basic NX kit and a gen x-2 accessory with the heater. It is nonrelayed...I'm wanting to redo my kit and heater since I got the nitro daves switch panel, and wondering which relays I need to use. Can I just get them from the parts store, or do I need to get them from a sponsor?
Old Feb 2, 2009 | 02:18 PM
Nick@HSW's Avatar
You can get them at most part stores, unless you also want the pigtail harness that comes with them. Make sure you get a high enough amp draw relay for the accessory you're using.
Nick
Old Feb 2, 2009 | 02:20 PM
stealth71's Avatar
30A will probably work, but check the amperage draw on the accessory to be sure and use the correct gauge wire.
Old Feb 3, 2009 | 06:24 PM
jdiddyws6's Avatar
I'm going to do both of my noids and the heater. 30 amp on both is acceptable?
Old Feb 4, 2009 | 09:55 AM
Nick@HSW's Avatar
We send out 40 amp relays with the kits. What kit do you have? I would call the mfg and see what the amp draw is on them.
Nick
Old Feb 4, 2009 | 01:36 PM
jdiddyws6's Avatar
I have the nx basic kit (non carbon fiber looking ones)
Old Feb 4, 2009 | 01:55 PM
jmill96Z's Avatar
You should be fine going to Autozone or Napa and getting a 30A relay. If they have 40's, you could do that too.
