Am I missing anything?
Old Feb 8, 2009 | 02:33 AM
Kingc8r's Avatar
Default Am I missing anything?
I have the following
Nos 78mm plate kit
Nos mini controller
Bottle heater
Blow down tube
TR6 plugs
28lbs injectors (buddy supplied)
Setup for 100 shot
I'll be buying a bottle holder/bracket, purge and switch panel
Thanks
I'm only interested in parts needed to run safely or is absolutely needed
Old Feb 8, 2009 | 02:48 AM
krazy4's Avatar
Add a purge to your setup. Other than that it seems pretty complete.
Old Feb 8, 2009 | 02:50 AM
Kingc8r's Avatar
I forgot to add that I'm buying that too. Thanks
Old Feb 8, 2009 | 08:43 AM
99BlackTransAm's Avatar
Window Switch or kiss your A4 good bie unless your Nos mini controller is like one?
Old Feb 8, 2009 | 10:48 AM
Kingc8r's Avatar
I believe it is
Old Feb 8, 2009 | 10:55 AM
Kingc8r's Avatar
It has a tps sensing switch, two rpm window switch and two progressive timers
Old Feb 9, 2009 | 06:18 PM
i say your good to go, unless you need a Fire jacket for the track?
Old Feb 9, 2009 | 09:18 PM
1sicws6's Avatar
Ryan I have a 360 bottle mount plate. lmk if your intrested
Old Feb 10, 2009 | 01:04 AM
Kingc8r's Avatar
Ok. Sounds good
Old Feb 10, 2009 | 03:32 AM
RealLiveMD's Avatar
Does he really need injectors for the wet kit? I'm getting mixed feedback. I'm also planning to take the plunge this week.
Old Feb 10, 2009 | 10:17 AM
Nick@HSW's Avatar
For a wet kit you won't need injectors. You will need to verify that the current injectors would be up to the task for whatever N/A mods you do.
Nick
Old Feb 10, 2009 | 11:20 PM
Nitro Dave's Nitrous Outlet's Avatar
Looks like you have a pretty good grasp on what you need. Add a bottle pressure gauge.
Check out the sales we have listed this week. Some items you may need are posted.
https://ls1tech.com/forums/nitrous-o...week-only.html
Old Feb 10, 2009 | 11:29 PM
johnLs1camaro's Avatar
i say add a HSW micro edge to it, well worth the money!
Old Feb 10, 2009 | 11:34 PM
No need to. He has the NOS mini and it has the ability to do anything he is looking to do.
Dave
Old Feb 10, 2009 | 11:36 PM
my bad i looked right pass that...
Old Feb 11, 2009 | 12:47 AM
Kingc8r's Avatar
Thanks for the help
Old Feb 11, 2009 | 03:12 AM
BayAreaSS's Avatar
Looks like its almost that time. Can't wait to strap this kit on and roll out
Old Feb 11, 2009 | 12:49 PM
Kingc8r's Avatar
Fa show. I can't wait to spray this car
