150 shot = 3HP
Old Oct 9, 2003 | 03:21 PM
LS1Formula98's Avatar
Default 150 shot = 3HP
I posted a few days ago about my dyno session last weekend, but I don't think anyone could really figure out my results.
https://ls1tech.com/threads/showflat...31&fpart=1
Anyone else know why I managed to get 411hp on a 100 shot and only 414hp on a 150? I dont think it was the bottle pressure, it was near 1000lbs for the 100 shot, but still over 900lbs for the 150. BTW: I do have some EFI live files that logged the 2 runs if someone wants to look at them. Unfortunately i cant get the program to run on my puter. TIA
Old Oct 9, 2003 | 06:58 PM
Bad Habit Bird's Avatar
Default Re: 150 shot = 3HP
It looks like you need more bottle pressure is all
Old Oct 9, 2003 | 09:25 PM
Really? I thought 900 or over would be suffecient. Well, what do you recommend?
Old Oct 9, 2003 | 09:53 PM
dekilo's Avatar
I dont think it is bottle pressure. Do another check on the jet #. Make sure you got the right jet in there. Even with 900psi, you still should make alittle more hp. But it also could be pressure, so get a bottle heater and get it to 1100-1200psi.
Old Oct 9, 2003 | 10:14 PM
Well, I was thinking the same thing as far as the pressure not being its full potential, but not so much that it would only give me 3 more HP than the 100 shot. The jets are correct, i made sure to check them before I used them. I have a bottle heater, but it's only set to 1000 psi.
Old Oct 9, 2003 | 10:35 PM
minivette's Avatar
ok, I logged the runs. Since he can't get the software to run, I'll post the screenshots from each run. Note the KR!
All motor
[b]100 shot[b]
150 Note the negative timing at the beginning of the run
Old Oct 9, 2003 | 11:04 PM
Thanks Wes, I wonder if this should be posted in the Computer diag section.
Old Oct 10, 2003 | 05:49 AM
lrmneil's Avatar
I have the exact same problem I have a 5177 kit that I switched to a wet. I am starting to think it the cats I still have on the car.
Old Oct 10, 2003 | 10:47 AM
Colonel's Avatar
"I have the exact same problem I have a 5177 kit"
The #5177 kit will not flow over about 135 HP even if you remove the jets.
Old Oct 10, 2003 | 04:20 PM
95LS1TA's Avatar
I have heard that some nossels only flow so much even if you take the jet completely out. It may be maxed out at 103hp
Old Oct 11, 2003 | 04:48 PM
lrmneil's Avatar
Whats a good nozzle to get?
Old Oct 12, 2003 | 09:13 PM
LASTLS1's Avatar
6 Second Club Moderator
From dry to wet! 5177 uses 30 amp relay wet uses 40 amp relay. 30 amps not enough to keep solenoids open. Fuel pressure swith, throw away. Make sure you have more than enough fuel supply!!! Happy trails.
