Can someone tell me what this is?
Robert
http://www.shopatron.com/product/par...EED00010/300.0
I've never seen one used on a direct port system before, how do you know when an accumulator is necessary? I'm going to be converting my NOSzle system to a traditional direct port and running a HSW standalone fuel system.....safe to assume I won't need this??
I would like to invite you to look at our systems as well. We are the ones who came up with the all in one dedicated fuel system design. We offer two different designs for the F-body. Either design cost 710.00
Our battery dedicated Holds one gallon of fuel and mounts in the factory battery location. The hold down clamp that holds the battery in place is what locks this dedicated firmly down.
Our Fuse dedicated was designed for the customer not wanting to relocate the battery. This unit mounts on the front core support by the radiator. Using this product will not require moving anything at all. This unit holds just alittle under 1 gallon.
All of our dedicated fuel systems come completely assembled. All you have to do is cut to fit the braided fuel hose and attach the ends. Our dedicated fuel systems also come complete with a wring harness, relay and a colored wiring diiagram.
We try to keep both theses designs on the shelf.
Just another option..
Dave
I would recommend Nitrous Outlets fuse tank for any direct port.
If you got the coin for some of the puzzle get the rest you will be glad you did.
