Best way to heat a bottle?
Old Feb 9, 2009 | 07:49 PM
Brian Coles's Avatar
Default Best way to heat a bottle?
Best way without a heater or torch? Have a full bottle but guage only reading 650.
Old Feb 9, 2009 | 07:52 PM
AChotrod's Avatar
Ive seen people put them on the grill!! JK.... dont try that!!!!!!!!!!!!!!!
94zson's Avatar
NANO kit
Old Feb 9, 2009 | 07:54 PM
Default Agreed
Nano in my future but don't have a bottle warmer yet and want to take a good test shot!!!
Old Feb 9, 2009 | 07:55 PM
Ice78Transam's Avatar
Bottle heater blanket. And it must be cold to only be reading 650.
I would use an indirect source of heat in the mean time. Not a huuge fan of torching a bottle of NO2.
Old Feb 9, 2009 | 07:57 PM
It's also been shown that repetitive farting on or near the neck of the bottle produces some results.
Old Feb 9, 2009 | 07:58 PM
I do have a heating pad ane electric blanket. Will that work or do I need a higher heat source.
P.S. stop laughing b/c it sounded just as dumb of an idea to me as I was typing it but I thought what the hell
Old Feb 9, 2009 | 08:00 PM
Bottle is room temp??
Old Feb 9, 2009 | 08:11 PM
AxisOfOil's Avatar
nano f.t.w.
heater blankets... like the kind you use on your bed... should probably warm it up a little bit.
Last edited by AxisOfOil; Feb 9, 2009 at 08:12 PM. Reason: apparently dumdumdum now means dumdumdum?
Old Feb 9, 2009 | 08:13 PM
Is it normal for a full bottle to read 650 at room temp??
Old Feb 9, 2009 | 08:23 PM
jeepers_88's Avatar
I think thats about what my pressure was last time I looked at it when it was full and room temp (not heated). I read a post not long ago about someone turning their heater on full blast and leaving the bottle in the floor area to warm up. The electric blanket will probably work pretty good. Just keep an eye on it since you wont have a pressure shut off switch. It should hold pressure long enough for you to make a good test run or two, but will start to drop off without constant heat.
Old Feb 9, 2009 | 08:28 PM
Default Thanks
I tried a pass just to see if my microedge and my interface were activating the system. They worked flawlessly!! I only have the 75 shot pill in but only saw very minimal seat of the pants increase at 650 psi??
Old Feb 9, 2009 | 08:41 PM
01SOMZ28's Avatar
i've personally done the heating blanket with a power inverter in my car, haha, it didnt really work it only brought the bottle pressure up about 100psi. My bottle is mounted in between my back seats and i've also pointed all the vents to the middle of the car and turned the heater on hi and left it for a good 5-10 min and it actually worked well, it brought the psi from about 750 to 1000psi
Old Feb 9, 2009 | 08:45 PM
Its up to 750 and climbing slowly with pad and blanket!!
Old Feb 9, 2009 | 08:51 PM
Talking i'll try anything at this point!
Missed that post earlier but my dog wont do it on comand and the wife refused to try. Ha Ha Ha
Old Feb 9, 2009 | 09:02 PM
evilbeef54's Avatar
i've also heard hot water from the bathtub
Old Feb 9, 2009 | 09:08 PM
SIKSIX's Avatar
Use a turkey fryer filled with water. Thats the best way I've found and no direct flame on the bottle.
Old Feb 9, 2009 | 09:13 PM
jetlag's Avatar
Napalm will keep the bottle hot all the time, no need to worry about keeping an eye on it.
Old Feb 9, 2009 | 09:17 PM
gsxr1k2's Avatar
Get a small trash can and put hot water up to the neck. Its that easy.
Old Feb 9, 2009 | 10:12 PM
porksoda's Avatar
I agree a tub of hot water works.
