Some please lend a helping hand with this nitrous dilema
Old Feb 11, 2009 | 10:31 PM
jboice06's Avatar
Default Some please lend a helping hand with this nitrous dilema
Hey guys just got my TNT f1 nitrous kit and its used but in really great shape and got a digital msd window switch with it too.... heres the dilema.... Just bought a 85mm prof products intake and 85 mm throttle body i ripped out the ac going to run some shorty headers has stock gears and no cats with single chamber flowmaster..... my problem is I was going to cam the car but I dont wanna dig into the car right now i dont even wanna put a converter in im super busy with my newborn and 2.5 year old.... so with my mods are a 11.99 possible with a set of mickey thompsons??? and could someone also explain pro's and cons to the ring setup tnt uses???? should i just spray 100... the car is a 99 and I've heard the rod bolts dont hold so well???? could someone shed some input
Old Feb 11, 2009 | 10:32 PM
jboice06's Avatar
wet kit by the way with purge and going to add slp line lock for good tire heating lol
Old Feb 12, 2009 | 06:57 AM
Robert56's Avatar
Boy that's a lot info your asking for. you may have better luck with one question at a time. it would take many paragraphs to cover all that you want. I normally would help in the areas i can, but super busy so i will cover one area. the rod bolts are normally addressed if your pulling the motor apart, but if your going smallish, many run stock bolts so just stay with a reasonable size shot and you will be fine. Only you can decide how far you want to push it, but if it were mine I would have no issue with a 100/150 and probably even hit it with a 200 every once in a while.
Robert
Old Feb 12, 2009 | 10:03 AM
1999TransamWs6's Avatar
I agree with Robert. Stay in the 100/150 realm and slap on a 200 every now and then. I would suggest however if you where to go above 150 at any point upgrade the fuel pump. As for going 11.99 dont see an issue with a 150, I went 12.00 with full exhaust a converter and a 75 shot and NOTHING else so a 150 should compensate for the converter IMO as long as it dead hooks and you spray it out the hole. I would say the things to concern yourself would be the stock tranny, fuel pump (just need some more fuel) and rod bolts just to touch first base with some issues you may run into. There are 100 other things that could go wrong obviously but those are most common.
go for it! I sprayed a 250 dry with a completely stock shortblock for a good while and never had any issues, did burn my tranny up though. Any questions feel free, good luck.
Joe
Old Feb 12, 2009 | 02:37 PM
LS1-NAVY's Avatar
if you have a stock rear end its going to hate you and probably kill itself
Old Feb 12, 2009 | 04:37 PM
The rear end will hold up much better on an auto with a stock stall. Mine never broke and I hit it with 667rwhp out the hole at about 4k rpm, But I know that is not common. I would think he would be safe. Now if it was a manual, different story.
