Quick question on a dry system
If i hope on a friends dyno and do a pull NA and then on spray and the AFR looks good should i worry about having her take the 100 pill?
Harris- You can smell it. Im not that well informed but a local speed shop said they were pretty sure it was as well. I have not bought to kit yet. I have 98 injectors. They should be ok on a bolt on car on a 100 shot right?
Its not likely, you will probably max them out. keep your eye on the injector duty cycle.
My bolt-on car had 86% injector duty cycle. Some people said that could have been because of a weak fuel pump. But if it really was 86%, then I was maxed out on a 100 shot. I never used it again because I got scared and added a Racetronix fuel pump and bigger injectors.
