Need opinions.
Old Mar 3, 2009 | 12:32 AM
Mean87SS's Avatar
Default Need opinions.
I am just looking for a 75-100 shot right now... maybe I should just look for a nozzle kit?
Anything specific I should look at? Wet/dry? specfid options... I know I'll need a blowdown tube, but what else is needed?
1998 Z28, 42# injectors, 236/240 cam, FAST intake, 3500 converter
Old Mar 3, 2009 | 05:55 AM
slowpoke96z28's Avatar
direct port...do it now and be done with it...
Old Mar 3, 2009 | 08:56 AM
Nick@HSW's Avatar
A nozzle or plate kit will be more than sufficient to reach your goals. As far as necessities, it really depends on which set up you end up going with. I would for sure recommend a window switch and nitrous filter along with the blow down tube if the bottle isn't going to be mounted behind a true firewall partition. A colder heat range of spark plugs are a must and looking at what you listed, I would also recommend a fuel pump if you don't already have one. Feel free to shoot me a PM or give us a call and we can put together a nice package for you. Thanks.
Nick
Old Mar 4, 2009 | 11:39 PM
Nitro Dave's Nitrous Outlet's Avatar
For the hp level you are looking for there are tons of options. Everyone has there own prefrence between wet or dry. I personally prefer a wet system for many reasons.
Here is a good non bias explanation between the two.
http://www.nitroustech.com/forums/showthread.php?t=92
Here is a good explanation on what the most used accessories are and what they do.
http://www.nitroustech.com/forums/showthread.php?t=2
If I can answer any questions and guide you in the right path let me know.
Thanks
Dave
