4ft an line
Old Mar 4, 2009 | 09:11 AM
domestic disturbance's Avatar
Default 4ft an line
i was jw before i order this line... would a 4ft line cause or be any problem feeding my fuel solenoid... Bc were i have my solenoids mounted its going to take about a 4ft line to run it from the solenoid to the rail....
jw if it will cause lack of fuel or anything!
thanks chris!
Old Mar 4, 2009 | 10:03 AM
Nick@HSW's Avatar
Chris,
It will be fine feeding the solenoid as long as the pump/regulator combo can support it. That line will be under pressure all the way up to the solenoid. My only concern is that I don't see a fuel pump in your signature...might want to think about swapping it to be on the safe side.
Nick
Old Mar 4, 2009 | 10:06 AM
Sounds good, Hey nick shoot me a pm on some brackets if you was able to find anything... !!!! thanks chris
Old Mar 4, 2009 | 10:13 AM
Chris@NitroDaves
Guest
Posts: n/a
With a fuel hose that long you will be looking at a potential lean spike on the initial hit. It is doable but I'd put it on a dyno or at least monitor the AFR on the initial first hit.
-Chris
Old Mar 4, 2009 | 11:18 AM
well hmmm I just had it on a monitor lol... ill see what i caint do on getting it looked at when i get it all set back up!
