complete noob to nitrous need help with fogger
I heard i can hide the nozzle behind the intake or under it but idk the truth to that
Anyways any help is appreciated thanks
Depending on how much nitrous you are looking to move, you may need to upgrade your fuel system.
Depending on whether you have coil packs or a single coil there are some options as to how to pull timing. LS1: Timing Tuner, Lingenfelter or just a good dyno tune. LT1 etc.: Mallory 685, MSD Digital 6 or a good Dyno tune.
If your dead set on a dry kit, you will probably have to upgrade your injectors to remain safe on fuel as long as your pump will handle the extra fuel load.
Nick
