Why nitrous NOW SUCKS for me...
Old Mar 22, 2009 | 06:05 PM
subhumanzz's Avatar
well i am glad i am not running the msd then.
Old Mar 22, 2009 | 08:18 PM
Z284U2TRY's Avatar
If you hit the purge button how would this activate the window switch? If wired correctly. It would be a seperate circuit.
Old Mar 22, 2009 | 08:39 PM
jmill96Z's Avatar
I always wire the purge independant from the system. Now if you have it wired to the master arm switch, you will have to arm the system to get power to the purge setup. With the system armed, and a failed window switch, if you bump the WOT switch it will spray.
Old Mar 22, 2009 | 09:51 PM
WJ MARK's Avatar
12 Second Truck Club
Thats why I run mine on the TPS switch. Sorry to hear about that. Atleast you're OK
Old Mar 23, 2009 | 03:22 PM
Robert56's Avatar
Yea it sounds like it sprayed instantly when you hit the micro sw, just long enough for an intake full of n2o only and thus the backfire. If it's the newer digital style MSD, yes they are known to be troublesome, but the pill style seems ok. When you get it back together make sure you disconnect the lines and then check for when it activates.
Here's a question that may shed light on the sticking noid issue. Did the rpms come up when you blipped it, then the back fire after you let off?
Robert
Old Mar 23, 2009 | 03:36 PM
dubrado's Avatar
Is it the DIGITAL MSD boxes that have issues?
I have the old school one w/the pills, never had an issue.
Old Mar 23, 2009 | 04:13 PM
02' hawk's Avatar
Robert
I really don't remember.... All i remember was a BIG flash then a BOOM! If i have to answer that question it would have to be a NO.
Old Mar 23, 2009 | 04:17 PM
02' hawk's Avatar
Originally Posted by bonestock99
Just a stupid question but why did you hit the microswitch at idle?
The micro swithch is there to activate the system and runs to a MSD digital window switch. The system should not have made a closed circuit until the rpm's hit at least 3,000 rpm's in the window switch. I have ran this same setup for 2+ years and never even had a hick-up! MUST HAVE BEEN THE W/S. I'm going to sell the nitrous and go with a 451 cu in from LME to compensate for the nitrous removal so this will NEVER happen again.
Old Mar 23, 2009 | 04:21 PM
02' hawk's Avatar
If anyone is interested in a wet setup from Nitro Dave's let me know..... and yes i will check everything to make sure it's ALL OK. (Guaranteed) It's a 10lb bottle,2 stage plate, -6 lines, and remote opener, bottle warmer, purdge...... the whole 9 yards. Please PM me if interested.
Old Mar 23, 2009 | 04:54 PM
fastGBcamaro's Avatar
PM sent
Old Mar 23, 2009 | 05:08 PM
02' hawk's Avatar
Sold!
Old Mar 23, 2009 | 06:17 PM
  #32
Robert56's Avatar
Yes, same here on using the old style pill sw.
Robert
Old Mar 23, 2009 | 09:54 PM
  #33
Nitro Dave's Nitrous Outlet's Avatar
Wow. Sorry to see this. Something electrical deffintly was wrong. Even if you hit the microswitch and the car was staying steady at the 3000 rpm range it should have not sprayed unless you had the toggle switch activated.
Yes you can send us your solenoids and we will check it out for you. Let me know if I can answer any questions.
Old Mar 23, 2009 | 10:33 PM
  #34
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That sold really quickly.
Old Mar 28, 2009 | 07:11 PM
  #35
02' hawk's Avatar
I was also really impressed with how quick it sold.
Old Mar 28, 2009 | 07:13 PM
  #36
02' hawk's Avatar
Thanks. The guy that bought them live over in your neck of the woods and said he is going to bring them to you soon.
Old Mar 29, 2009 | 07:43 AM
  #37
bonestock99's Avatar
Even if the window switch is bad, that still didn't answer my Q. WHY DID YOU HIT THE MICROSWICH AT IDLE. What did you think it was going to do? Were you testing something? Just think, if you didn't hit the switch what would the car look like now? And how much money would you have spent fixing it? Learn a lesson here don't do stupid **** just because you can.
Old May 4, 2009 | 04:37 PM
  #38
02' hawk's Avatar
If i own it i can do what i please..... It's almost like; is the bottle half full or half empty? BOTTOM LINE IS IT SHOULD NOT HAVE SPRAYED UNTIL IT WAS WITHIN THE WINDOW SWITCH RPM'S.
Old May 4, 2009 | 05:50 PM
  #39
Well you CAN throw rocks in the intake of the procharger.....but I wouldn't recommend it! LOL HAHAHAHA!!!
Old May 5, 2009 | 07:27 PM
  #40
Dragframe's Avatar
Your an idiot.
