ARP Bolts or Head Studs?
I did some searching and found a couple guys saying heads for 250 shot.
I have an HKE built 347, with rings gapped for 150 shot. I'm using AFR's again with a stock thickness Cometic gaskets.
From my last setup, I have ARP head bolts.
My question is, will the ARP head bolts be enough to hold down a 150 shot? The last thing I want to do is push water so if you think head studs are the way to go, let me know.
Thanks
Yes they are neccessary....why spend all that money on building an engine then cheap out at the end? Of course people have ran bolts and been okay..but is it really worth saving 100$ now and risking your engine down the road? I went with them now and I dont even need them..its just an extra piece of mind..and its worth the extra 100$
IMO OP, I would just use the ARP head bolts since you have them. No need to spend more money.
