Wiring window switch
Old Mar 21, 2009 | 04:55 PM
Dabeztz28's Avatar
Default Wiring window switch
Any one have any pics of how the wired up the window switch? I have a dynotune window switch and just dont get an idea of of to get the TPS signal and RPM signal of the pcm. Do youjust just follow the wires and splice into them?
anyone have a pic or diagram of the pcm pin layout.
thanks
Old Mar 21, 2009 | 04:58 PM
subhumanzz's Avatar
pin 10 is a white wire which is your rpm signal and pin 28 is a dark blue wire which is your tps signal.
Old Mar 23, 2009 | 07:56 PM
blakern's Avatar
Ha I was about to ask the same questions.
So its (pin 10, white wire, rpm signal and pin 28, dark blue wire, tps signal) is this correct for all years? Mines a 98.
Heres how I have mine wired so far. Hows it look compared to yours, or is mine all jacked up?
