Best timing tuner
Robert
Best, easiest option on the market....
My second option would be the timming tunner or MSD twister. These devices use the most reliable and accurate method of pulling timming.
Dave
Nick
This is a screen capture of what I changed selecting the 158° column. This advanced feature requires the use of a tuner program, but well worth it for the more advanced users.
This is the same car but a stock screen shot. So you can see by selecting different columns you can pull different amounts right out of the box with-out a tuner program or lap-top. You just need to see the look up table for your car.
Robert
Dave
Robert
No, it does not automatically remove that much timing. You will have to change a few switches.
Wow thats cool...looking to get a 100 dry shot. I already have a wideband, it runs at 12.9-13.1 at wot. What is a good a/f to run while spraying?
I don't recommend you do that unless you have bigger injectors. My car now has a Racetronix fuel pump kit and SVO 30# injectors. Also, with your car being a 99, you will probably be maxxing out your stock injectors. They are smaller than 98, 01-02.
High 11s is good.
Here is a picture of how easy it is to set....just flip a few switches!
High 11s is good.
Nice!
When I picked up my used ls6 intake it came with some 98 28.5(?) injectors. Did you tap the nossle right into the bellows? I have the smooth one. Did you run the 11.0 on the 125 shot? What did it run on motor?
thanks
<- Image linked to product on site just...... click pictureIMO the Lingenfelter unit is the best timing control device out there....You can also hook it to HPtuners or EFI Live and actually see the timing being pulled out to make sure it' working properly.
-Chris
How can it hook up to LS1edit? As far as I know there isn't a analog input available on them unless it has been updated. Also, according to the directions, you also need to input values into HP Tuners to equate with the voltage signals being sent out the analog output. 0 volts equals 0 degrees and 3 volts equals 15 degrees which will then offer an independent line item showing the incoming signals as timing being pulled, but not the actual timing curve. I also want to note that a scan tool will still not see the timing being pulled as it is after the pcm. It is a very nice feature that they included in the device to verify that it is doing its job, but its not as simple as just hooking up a wire as you indicate and that the signal coming out is still just a verification that it is working in the form of reference voltage.
Nick
So the car has 10s easy, but every single track day has been rained out recently. Sunny and 60-70degrees all week, race day and its 40 and raining, then after race day is sunny and 60-70 again. That has been happening for 4 weeks.
