Please help with my leak
Old Mar 30, 2009 | 07:45 PM
bowtiebubba1's Avatar
Default Please help with my leak
I have been messing with this for a week & dont know what else to do.I am trying to install a flo-thru manifold on the end of the fuel rail on my 2002 corvette. I have tried 3 different ones and everyone leaks at the plug in the port that im not using. What can i do to fix this? We have our first show this weekend & im beginning to think i cant fix this.
Old Mar 30, 2009 | 07:51 PM
johnson73801's Avatar
what kind of plug is it? is it pipe or an? if its pipe did you use a sealer? if its a an plug does it need a oring or a teflon washer?
Old Mar 30, 2009 | 08:01 PM
Its a AN manifold and i put the teflon paste on it,but still leaks.
Old Mar 30, 2009 | 09:20 PM
i would use a plug that uses a oring or washer for a sealer instead of paste they say that ans dont require paste because of the flare seal
Old Mar 30, 2009 | 09:44 PM
JoeyGC5's Avatar
Are you tightening the **** out of the unused port plug? If nothing else use the paste and let it sit/setup before pressurizing the line.
Old Mar 30, 2009 | 10:10 PM
=ZoomZ='s Avatar
I bet its an An adapter with an NPT port plug .
1/8-27 npt plug and some teflon tape should handle it .
Old Mar 31, 2009 | 07:47 AM
Yes,it has the npt plugs.
Old Mar 31, 2009 | 07:17 PM
Thanks for the help guys. Went and got a brass plug used it instead of the one that came with it. No more leak. Thanks again.
