how much nitrous can a ls6 intake flow?
Old Mar 30, 2009 | 09:13 PM
30th6's Avatar
Default how much nitrous can a ls6 intake flow?
ive searched and cant find anything.im wondering how much the intake can flow safely without leaning out cylinders.im wanting to spray a 200 shot through a plate. i may also put on a second stage with a 50 shot depending on your answers... thanks,joe
Old Mar 30, 2009 | 10:29 PM
mchdg86's Avatar
Most people say anything above a 200 shot you should go direct port.
Old Mar 30, 2009 | 10:39 PM
jmill96Z's Avatar
I've run a 200 shot through an LS6 for 2 straight years. Mine was setup dual stage though. The car would always feel like it kind of nosed over on the big end, but the MPH didn't really show. It just felt like it was running out of breath.
Anyways, I wouldn't spray more than 200 through the front if it was on mine. I try to be safe though. It makes **** last longer.
Old Mar 30, 2009 | 10:43 PM
TARZAN's Avatar
I've *seen* 250 through an LS6. I personally wouldn't spray more than a 175-200 through one.
-Will
Old Mar 31, 2009 | 12:23 AM
dnkynrbk's Avatar
no more than 200 unless you have hp tunners and can watch it. What fuel set up are you running? What plugs? what timming? Do not do that much of a shot off you fuel rail you could lean out that side of the motor then POP. I ran a nitro dave dedicated with 116 fuel in the tank have had several low 10 sec passes running a 200 shot thru the fast 90. Talk to a sponsor on here.
Old Mar 31, 2009 | 01:00 AM
MelScrilla's Avatar
with a stand alone fuel system can you still run pump gas through the main tank if you have the 116 in the dedicated nitrous tank? And i was also wondering what it would cost to setup a standalone fuel system for nitrous.
Old Mar 31, 2009 | 01:11 AM
jmill96Z's Avatar
Here you go: http://www.harrisspeedworks.com/shop/home.php?cat=68
Old Mar 31, 2009 | 08:37 AM
Mike@HSW's Avatar
That's one purpose of a standalone, too be able to run a higher octane fuel. We've actually run up to 275 shots on an LS6 intake with our standalone system and two stages. I don't recommend that, but it is possible. As Jeremy said, you will mostly be losing out on the top end.
Let me know if you have any questions about our products.
Old Mar 31, 2009 | 03:01 PM
Sigforty's Avatar
I would not be worried about how much the intake can flow. I would be concerned about two other things.
1. The intake is designed to flow air not fuel. So if you are running a wet shot I would not want to flow more than a 175 shot worth of fuel through the intake.
2. Due to the intake design you have to worry about leaning out cylinders 5 and 7. So for anything over a 175 I say go direct port. That way you can properly get 5 and 7 a little heavy on fuel.
Old Mar 31, 2009 | 05:44 PM
30th6's Avatar
can i run 150 shot off of the fuel rail? ill have a fpss in place to keep the fuel presure safe.
Old Mar 31, 2009 | 05:51 PM
Mike@HSW's Avatar
yes...just make sure your fuel pump is up to the task
Old Mar 31, 2009 | 06:44 PM
30th6's Avatar
ok ive been looking at a nitrous mastermind and it says you have to use aftermarket ignitions.why? i dont want to buy a lot of ignition parts to get this to work.thanks joe
Old Mar 31, 2009 | 07:38 PM
Sigforty's Avatar
Maybe on older cars, but on newer stuff the ignition is perfectly fine.
Old Mar 31, 2009 | 07:44 PM
30th6's Avatar
sweet.......
Old Apr 1, 2009 | 08:21 AM
Noyzee's Avatar
8 second mod
i ran 300 threw DP on ls6 and 250 on daves plate on a fast 90. no issues
