which aluminum intake?
Old Apr 9, 2009 | 02:13 AM
iverson387's Avatar
Default which aluminum intake?
Im looking to get an aluminum intake for my car to be safer in case of a backfire and hopefully to pick up a little power. Currently i have a ls6 intake, mods are forged 347, prc stg 2.5 5.3l heads, ms4 cam. I am going to be spraying a 200-250 dry shot. Are there any decent aluminum intakes that will fit under the cowl of a 99 camaro? BBk ssi? weiand? holley?
Old Apr 9, 2009 | 06:07 AM
itsjustaSB's Avatar
i have a bbk and am pretty happy with it just made the numbers in my sig i think its choking it alittle up top though but other than that it is a good intake for the money
Old Apr 9, 2009 | 06:43 AM
iverson387's Avatar
nice i think im gonna get it. What throttle body are u using with it?
Old Apr 9, 2009 | 06:56 AM
Mike@HSW's Avatar
do you want an aluminum LS style intake or a single plane?
Old Apr 9, 2009 | 10:58 AM
jmill96Z's Avatar
I'm not a huge fan of the aluminum version of the stock intakes. They turn into a heat sink. You could have burst panels installed into your LS6.
Old Apr 9, 2009 | 03:09 PM
BAKED's Avatar
Those BBK's suck dick. I've NEVER seen one do very good on my buddies dyno. One guy swaped out his LS6 for the BBK and lost 8-10 hp across the board! More so on top end than anywhere else.
If you go with a single plane I'd go with the GMPP. From what I've seen you lose a little more on bottom with the Victor Jr and you have to twist the ***** off of your engine to really benefit from it. I lost about 12rwhp on bottom end but gained back almost 20 from 4K on up with my GMPP single plane.
