Opinions needed.....one bottle or two?
Old Apr 7, 2009 | 03:13 PM
TravisA's Avatar
Default Opinions needed.....one bottle or two?
I just completed my nitrous install and need some opinions on running one bottle or two for a two stage kit.
Both are nozzle setups and the first stage is 100 off the line with the second one(150hp) coming on .5-1 sec after launch(via microedge)...So should I run two seperate bottles per kit or use a y and run just one bottle for both stages?
Thanks!
-Travis
Old Apr 7, 2009 | 03:17 PM
Mike@HSW's Avatar
what shot size is the second stage?
Old Apr 7, 2009 | 04:18 PM
TravisA's Avatar
Whoops sorry..I had it in there and edited it out.
Second stage is 150..
Mike, I really like the microedge! I haven't had a chance to spray it yet but it seems like a great product!
Old Apr 7, 2009 | 04:28 PM
Mike@HSW's Avatar
I would Y the bottles together. You don't technically need it, but it will help keep your bottle pressure up and you will get a lot more runs before a change.
Great to hear, how was wiring and programming it?
Old Apr 7, 2009 | 09:16 PM
TravisA's Avatar
Wiring of the microedge was a breeze...I just followed the supplied schematic. It didn't take long after toying around with it to get the programming down. With all the features I think its well worth the money.
Now back to my setup...I have both nitrous lines ran to the rear off the car so I was going to run one bottle per kit or one bottle y'd into the two main lines.
So are you saying to y the two bottles into one mainline and then y again at the noids?
Old Apr 7, 2009 | 09:42 PM
dpinson's Avatar
yes he is,i believe
this way both bottles are keeping up the pressure in one main line
Old Apr 7, 2009 | 10:47 PM
TARZAN's Avatar
The only reason I would consider not running them into a "Y", is if you do not intend on using but 1 stage most of the time....I'd say you would be better off keeping a reserve bottle of sorts, if the 2nd stage is going to be a rarity.
Just a thought
-Will
Old Apr 8, 2009 | 08:12 AM
TravisA's Avatar
Anytime I'm running both kits will be used.
Old Apr 9, 2009 | 05:44 PM
02 BLK WS6's Avatar
2 bottles, 2 feed lines
