Fuel saftey pressure switch for nitrous
I am in the process installing the new nitrous system from Nitro Daves, my question is do you install the pressure switch after the fuel soleniod right before the nitrous 92mm plate? I would think so in case the fuel soleniod fails but not sure.
Or just install straight off the fuel rail to only protect from fuel pump from failer?
Thanks flawless, I have it installed / attached on the fuel rail then the fuel line is attached to that, then soleniod. Did not see regulator on fuel rail (98 Camaro) could it be on the left side looking at the engine?
Also what if the fuel soleniod fails and the engine gets just the nitrous will the window switch (Nitro Daves 2 stage) detect this?
Thanks for your help!
