Nitrous & Fuel Solenoid
Old Apr 15, 2009 | 10:18 PM
jester ls1's Avatar
Default Nitrous & Fuel Solenoid
Ok I finnaly installed everything and sealed up all leaks (was a bitch!) rewired a few missed steps, because the diagrams were for seperate accessories! Now Everything works! But one problem
Both the nitrous and fuel solenoid click and spray gas into the air intake just by arming. The bottle is off so just gas and the car floods. Went over all wiring and programming again with Chris (Nitro Daves) and he told me it is because I ran the 12 volt trigger and purge (through fire wall) together (2) conductor wire and is now getting solenoid chatter!
So I ran one single new wire from arm switch (12 volt trigger) home run and it still does it! (no ware near the purge) The solenoid should not kick on untill 3000 rpm's but kicks on as soon as you push the arm button. Any ideas?
Old Apr 16, 2009 | 08:04 AM
Sigforty's Avatar
Are you running any electronics such as a window switch, progressive, etc? If so you might need to check their settings and wiring.
Old Apr 16, 2009 | 09:25 AM
Nick@HSW's Avatar
I agree, its something with the wiring or a window switch setting if he's running one.
Nick
Old Apr 16, 2009 | 09:26 AM
Nick@HSW's Avatar
If you can, post a diagram of how the car is wired.
Nick
Old Apr 16, 2009 | 09:33 AM
SMAX's Avatar
Check your wot switch too.
Old Apr 16, 2009 | 01:50 PM
jester ls1's Avatar
Thanks for the help guys, I went over all the wiring with Chris at Nitrous Outlet and there were some problems. After rewiring the two wires (white off window switch) and (Yellow) everything seemed to be ok. Then go to arm and both soleniods fire twice. This sprayed gas into the intake and now the car wont start. How long should I wait to restart? I am taking this over to Gforce. Next week
Window switch & cable TB (6 speed) 1998
Old Apr 16, 2009 | 04:00 PM
Sigforty's Avatar
Who makes the window switch you have? How do you set the switch up? Give us some pictures or tell us what wires you have going where.
Not sure what you have, but this is how I would have something similar wired. I would have power and ground to the arm switch. The arm switch output would go my window switch. The window switch would then output to the WOT switch, and from the WOT finally to the nitrous relay. As for the noids they would be wired from the relay and a ground. Now some changes may be needed if you have a more advanced window switch or FPS and other switches being used. What you need to do is disconnect the relay from the system and wire up a light to the input from the Window switch to the relay. Then you could use the test light to start checking modifications from there and keep the noids from firing.
Old Apr 16, 2009 | 04:17 PM
TARZAN's Avatar
I would have guessed you were using an "a" prong on the relay, or the direct connection on the WOT switch...
-Will
