First n2o passes, ok but needs work...
Best N/A to date was.
13.035 @ 103.96 wit 1.807 60ft
Today I ran a best MPH of 111.72 on a 100shot
And a best time 12.515 @ 108.0 wit a 1.886 60ft on a 125shot, way to rich 9.sumthing A/F
Im not happy yet with it. Need to get that 60ft down, but it was the first track day of the year and it rained last night so I just couldnt hook on the DR's today.
now my best time is 12.8 after i leaned it out some. never ran it on spray after that. i got a bad bottle and said F it and bought a turbo!!!
maybe you got a bad bottle. more details!
Jetting/tuning work and traction, should get me where I want to be.
Air has an average molecular weight of 29 (28 for N2*.8 + 32 for O2 * .2)
1 mole of gas at STP occupies a volume of 22.4 L, therefore, 29g {~1 oz)of air at STP occupies 22.4 L
Take you tank volume in Liters (ft3X28.3 or cu in X .0164) and correct to STP (forget the temperature, just multiply the volume by 204 or 306{3000psi/14.7psi; 4500/14.7psi}. This gives you the gas volume at STP.
Divide this volume by 22.4 and you get the weight of air in oz.
Using that, you get the following information:
3000 PSI = 204 atm
4500 PSI = 306 atm
47ci = 0.77 L
68ci = 1.11 L
88ci = 1.44 L
114ci = 1.87 L
So now, just plug it into what I said above, and you get these weights:
47ci 3000PSI tank: 7.0 ounces of air
68ci 3000PSI tank: 10.1 ounces of air
88ci 3000PSI tank: 13.1 ounces of air
114ci 3000PSI tank: 17.0 ounces of air
47ci 4500PSI tank: 10.5 ounces of air
68ci 4500PSI tank: 15.1 ounces of air
88ci 4500PSI tank: 19.7 ounces of air
114ci 4500PSI tank: 25.5 ounces of air
One guy claims he got 7lbs of air in a nitrous bottle, next guy says it's weightless, then you define its weight with a pressure unit.
My old thermodynamics professor would definitely drop a turd if he read this thread.
I dont think there is anything "really" wrong with my setup, except jetting and traction. Most bolt-on cars run mid 13s here so a 12.5 on 100 shot dosnt seem that bad to me. You gained 10 mph and I gained 8mph on a 100ish shot.
What is the DA at the track you run?
Look at the bright side, you went to the track and sprayed it, you drove it home....Thats all that should matter...I am sure with some jet changes you will get it running good...I would suggest taking it to a dyno just to "check" a few things. I guess I shouldn't have said you have "something really wrong". I dont know all of the facts about the track or DA or anything....
Good luck with it man. Let us know how it does the next time you go to the track!
